I want to put in my 24's but I don't want to pull the upper intake just to do that, i would rather wait until I buy some heads after christmas. but is it possible to get to the bastards without pulling the upper intake?
CManT1914 said:Not realyl, not that I've found. Sorry, looks like you need to pull the intake off,.
EDIT: Besides, its not hard ot puill the upper intake off. I cna have an inatake pulled off and replaced in an hour.
mo_dingo said:yup, yank the upper.....It's really easy. 6 bolts, another 4 to disconnect the TB, some vacuum lines and you are set.
Scott
18mustangs said:Why would you unbolt the TB to pull the upper intake? Just unbolt the upper intake's 6 5\16" bolts, and the 2 10mm bolts for the TB cable bracket the vacuum lines, and 1 snake clamp on the stock inlet or CAI and your'e good to go.
Tim
Pokageek said:How in the @#$% do you torque down the rear bolt on the TFS upper intake? I just tighten it because I never could get to it.
i could with a swivel but it takes some time, those tfs intakes have weird bolt access IMO.Pokageek said:Doesn't workee for me. I can't get the 10mm 12 point socket in there..![]()
This isnt the proper way but on mine all i did was used an open/closed end wrench and tightened it down bout the same as the other's. No leaks no worriesPokageek said:How in the @#$% do you torque down the rear bolt on the TFS upper intake? I just tighten it because I never could get to it.
And no there is almost no way to replace injectors with out pulling the upper, just make shure to lube them when replacing them/ putting them back in.peace
i used studs which made it easier to get to, but there was no way to get to it with a torque wrench; at least i couldn't figure any way to. someone said to to use a dizzy wrench (which sounded like a good idea), but i couldn't find one that fit the nut.Pokageek said:How in the @#$% do you torque down the rear bolt on the TFS upper intake? I just tighten it because I never could get to it.
what about the egr? i'd unhook it at the elbow.18mustangs said:Why would you unbolt the TB to pull the upper intake? Just unbolt the upper intake's 6 5\16" bolts, and the 2 10mm bolts for the TB cable bracket the vacuum lines, and 1 snake clamp on the stock inlet or CAI and your'e good to go.
Tim
