can i use std base circle with this
Yea, you'd need a reduced base circle cam to use the factory style roller lifters. Crane makes a set of link bar hydraulic rollers that can be used with the off the shelf std base 5.0 roller cams but they cost somewhere north of $400.
Every cam mfg makes solid rollers. Take your pic. But you'll need screw in studs, guide plates, springs, retainers and full roller rockers to take advantage of a solid roller. Then you'll have a rev potential that'll over power the bottom end.
