Can MAP or BAP interchange
gregsmy
30
I was going over things and checking the previous owners work when I discovered that he has the original MAP sensor plugged into the connector for the BAP sensor but with no vacumn line attached. I have read that they are similiar in function but calibrated differently. Should I replace it? It has a "Painless" wiring harness and the connector is labeled BPS (barometric pressure switch?). I verified it by the part# on the sensor.
If it was once a speed density car that was converted to mass air, then yes, it should be fine. With the speed density, the MAP sensor provides input for how much fuel it estimates the car needs. Once it's converted, you leave the MAP open to the atmosphere and use it as a BAP sensor.
Yes the drivetrain was from a 87 Lincloln VII LSC that was originally speed density. When he put the drivetrain into the truck he bought an aftermarket "Painless" wiring harness and a computer and mass air flow from a later model mustang.
