Can someone post a pic
i got a radiator coming. i was just wanting to see how my current compares to a stock one. the PO cut the battery tray to fit this radiator in there so dunno how big a stock one is.
a stock 3 core radiator is coming and i bought a 5 bladed steel fan with a stock fan shroud. that should make it better seeing as EVERYTHING would be new (all that plus the water pump and 180 t stat).
on the stock shroud tho... its TINY compared to the one i fabbed up. around a 1/4 of the depth. mine goes form the radiator to almost the power steering pump/
You probably won't have any problems with this set-up.
The stock rad, flange to flange, will be about 1.5 inches wider than the opening in the rad support. However, if they cut out the battery tray then they may have cut the opening wider and the mounting holes along with it. Perhaps you could post a picture of your rad support?
