Can the doors stay on when doing the hinge reapair?
gw64cpe
24
Northern Kentucky
I just ordered the hinge repair kits for my 64.5 coupe. Does anyone know if I can leave the doors on, support them from below, and do one hinge at a time? It looks tight in there, but I'm not sure how much work is involved in installing the kit. If anyone has done this repair, I sure could use some pointers. Thanks.
66 BLAKE 96 said:
Perfect timing on this thread! :D
I'm just about to tackle the hinges as a part of the pre-paint process. :nice:
I should've known to check DesertMustangs.com first.
:D
I have a couple other links to bookmarked at home. I do know if you do a search on either
www.mustangandfords.com
or www.mustangmonthly.com
or hinges you'll find a couple pictorial write-ups for 65-67 stangs, but you have to do a search because they are not in their 'tech articles' section :D
But i can't access the search function on teh site here at work *shrug* otherwise i'd post the direct link.
Sorry to bring back an old thread, but what force of nature does it take to get the old pins out?
I've tried everything short of an industrial press (BFH, drill press), and those things just are not gonna budge. Am I missing something obvious?
Blake you need to drill out the thin metal 'hat'
Then punch out the pin using a correctly sized punch:
I'm pretty sure it's the same for the 65-66 hinges. I'll look on my 65 coupe in the morn and report back.
I replaced the pins with the door and the fenders on the car. Did one hinge at a time and used wooden blocks and a jack to support the door. It was a suprisingly simple job and took only 2 hours for both hinges! The alignment that had to be done was minimum.
Good luck
Erwin
Mine were tough to do
Mine weren't as easy as others here. I left the fenders on, but did take off the doors. The pins were frozen in pretty good, had to do a lot of banging in a vice on the bench. Took a lot of grinding and cutting too. It was over 5 hours to do all 4. They work great now though. Another hard part was realigning the doors, as I had to put them on, test, take off, adjust hinge, put on, test, repeat etc. Moral of story: don't try to save $$ by not replacing hinges before painting/assembling car!
Brian; I followed the directions up to that point to the letter in your how-to. The hats are drilled, but I haven't been able to budge the pins no matter what I throw at 'em. :(
Its getting really old having the only classic Mustang with hinges that isn't an "easy couple-hour job". Forget the frickin time frame, it looks as though I can't do these things with 20 hours of bangin' on them. At +/- $25 per hinge, buying new hinges isn't really an option. :mad:
When I did the hinges in my 68 I took them of the car to make it easier. I grinded the top part off completly so the pin was flush with the top of the hinge, while being careful to not grind the hinge. Then I used a really BFH and a punch to drive the pin out. Also make sure that no one weled the pin on the bottom side of the hinge to the hinge. You could try to put some penatrating fluid inbetween the pin in the hinge and let it sit over night.
Mario
