can't get car to idle down below 2 grand
billison
I like tinted tail
2,607
1,094
184
stl
i have a hard time getting my car to idle down below 2 grand, here is what i have, It's a 85, former cfi car, just put a intake and carb, procomp hei dizzy, still has stock fuel pump and i have the idle screw all the way back. The only things i can think of is maybe the stock pump is giving to much fuel or maybe it has something to do with my choke? thanks for the help.
i'm starting to think so, maybe a fuel regulator, i'm gonna get a fuel pressure gauge and see what my pressure is, is there a good way to test my choke "it's electric"
i'm thinking it's the fuel pump, i checked the vac lines and replaced one and fired it up and ideled at like 12 g, i was like rock on, but it died after like 30 seconds, and i realized i did'nt turn my fuel pump on, so i played with it a bit and found if i had the pump on the rpm's stayed high, but if i turned it on long enuff to get pressure then turned it on the rpm's stayed lower, so i think i need a regulator
