Get a flat screwdriver and pop the center plastic portion out of the door, the one with the switches on it. Pop off the little triangular plastic piece on the top left part of the door. Pull the plastic trim piece around the handle off too. Behind the center portion where the window switches were, there are 2 screws, pull them out and lift the door up, you will see how it is attached to get it back in. Don't try to pull straight out, you have to pull/push it straight up.
Joe
