Car Died
CKYlndSpd21
34
Alright so I was coming home from a buddies house the other night going threw some corners at a quick but not full out pace when all of a sudden I press the gas and I get nothing. Car is dead so as I'm coasting I try starting it and nothing. I pull over look under the hood everything looks fine I try starting it a few more times and still get nothing. I listen for the fuel pump and I don't hear it so I'm pretty sure the fuel pump went south. But is it common for fuel pumps to die out while the car is on and moving?
Yea def. check the inertia switch...its in the hatch and theres a little round rubber grommet that pops out and the button is right there and u just got to press it. Im not sure if u have a hatch or not so i dont no where it would be in a coupe. U can also try "hotwiring" the pump to come on. At the Diagnostic connector under the hood, put a wire from the bottom right pin to any clean ground and u should hear the fuel pump buzzing away. U could try pulling codes also and check the fuel pump relay but ive never heard of them going bad while driving. I would try pulling codes and checking fuses first since theyre free.
does the car turn over at all? if it does, im with those guys ^ about the inertia switch. a friend of mine pulled into his driveway too fast once, and tripped the switch
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Bill, the SN95's have the underhood fuse box. Foxes have a bunch of crude fusible links off the remote mounted starter solenoid instead.
CKY, the best thing to do would be to look up Jrichker's no start checklist. Start going down it and you will find the issue.
Good luck.
Good luck.
10-4! THANKS AGAIN
Okay so I fixed the problem it ended up being the fuseable link under the hood. But then last night I was pulling out of my neighboor hood when it died again so I stopped opened the hood messed with the fuseable link and got the car to start back up so I continued driving until it died again. I try messing with it again and wont start back up. So I park it and get a new fuseable link this morning and put it on but it still isnt working. Can anyone help me out?
if it burnt up then there must be something wrong with the wiring or somethig somewhere, thats why they have fusible links so they burn up instead of the device its protecting. Find out whats in that circuit and look over everything in it
