Car dies after an hour!
  • Thread starter Thread starter spyder2455
  • Start date Start date Mar 10, 2006
spyder2455
37
  • Mar 10, 2006
As the title says, my car has been dying after about an hour of stop and go driving in warm weather. It always happens when I come to a stop and suddenly the idle will drop to around 600rpm and if I try and give it gas I can keep it running for a second, but eventually it will just die out no matter how far I push down the pedal. Once this happens, I attempt to start it by turning the key and pumping the gas pedal. Finally, after about a minute of cranking it over in traffic it will fire up and as long as I keep the rpms above 1500 I can get it home and out of the street. I have had this problem for as long as I can remember, and I have just been avoiding driving the car for too long. I have replaced the TFI module (about 6 months ago), distributor (after the stator went out), coil, fuel pump, fuel filter and pretty much every other sensor in the time I have owned the car. My thoughts still lean towards the TFI because this occurs when the car gets warm, however I have already replaced it twice. I plan on having the TFI checked tomorrow, but I need some ideas on what else could be causing this. If it happens to be the TFI, why would it go out so soon? Please help!!!
HISSIN50
34
129
Mar 10, 2006
  • Mar 10, 2006
Pull the diagnostics codes. A PIP is another option, and it often doesnt pop a code.
When it craps out, if you dont goose it, do you know if you have spark and injector pulsing? How is FP when it does this?
You have replaced the 3 biggies that I would normally think of, so more diagnostics might be revealing. When you have the TFI tested, be sure they do it repeatedly to heat it up.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 10, 2006
  • Mar 10, 2006
Did you put a fresh coat of thermo grease on the back of the TFI when you installed it?
spyder2455
37
  • Mar 10, 2006
the supplied grease was applied when I installed the module... I will get it tested as soon as possible. As I was brainstorming on the situation I realized that this problem started ever since my alternator caught fire and the fusible link that leads to the starter solenoid melted. I replaced the link and rewired the alternator using 6 guage wire and I'm wondering if its possible that the fusible link i replaced it with might be too short. I figure if this heats up it can prevent proper voltage from reaching my computer and ultimately stalling the car. Any thoughts on this?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 11, 2006
  • Mar 11, 2006
I don't think it would make any difference, but a voltage check with a good DVM would tell immediately.
spyder2455
37
  • Mar 11, 2006
TFI tested ok after three tests(to heat up). I looked into a fuel pressure guage but they want 50 bucks for one so I figured I might as well buy one I can put on there permenately. Even though I have a new pump, bad fuel pressure is the only thing left I can think of.
K
kr mstg
18
  • Mar 11, 2006
Do you have a ignition system?? I had a MSD that was going bad and after i would drive it a while and slow down it would die. It took anywhere from 10- 20 tries to get it start up again. Needless to say i took it off and wired it up st8t. I never had the problem again.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 11, 2006
  • Mar 11, 2006
keep in mind it could also be a connector somewhere that is causing this or a relay overheating.
spyder2455
37
  • Mar 11, 2006
I do not have an aftermarket ignition... and I agree that it might be something electrical due to the effects of heat on old connections/relays. On thursday I plan on installing a stage 1 cam, and along with it I am going to get an adjustable regulator a fuel pressure guage. When I pull it apart I'll be able to check all my connections thouroughly and maybe I will run across something.
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Today at 5:04 PM
alutwon
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
3K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
