  • SN95 4.6L Mustang Tech
Car dies on me at a complete stop?
  • Thread starter Thread starter brandonh06
  • Start date Start date Jun 25, 2007
brandonh06
27
  • Jun 25, 2007
About 5wks ago i installed my SCT Xcal 2 Tune in my 2001 Mustang GT. It was for my Cams and all my other mods. Ever since then when i come to a complete stop my car dies and when i'm out driving around and let off the gas the car becomes hesitate until i give it gas again. I honestly don't know what the problem could be. If anyone has any information for me please let me know.
Thanks,
Brandon
D
Dragstr05
643
Stafford VA
Jun 25, 2007
  • Jun 25, 2007
Symtoms sound like an IAC. Started mine up one day and it didnt want to idle, at all. Pulled the IAC off, cleaned it out and runs fine since. Give it a try, will cost you 30mins of your time and about $4-5 for a can of carb cleaner.
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Jun 25, 2007
  • Jun 25, 2007
I was going to say IAC as well, until I read the part about the cams. is it a mail order tune, or did you get a dyno tune and bought an xcal2 to load your tune.
brandonh06
27
  • Jun 25, 2007
i bought the XCal2 from americanmuscle.com and they created the tune for me. so all i had to do was plug it in and install the tune.
Stang|ess
Oct 18, 2003
941
Hawaii
Jun 25, 2007
  • Jun 25, 2007
mail order tunes for cams aren't very good, which is most likely why you're dying. get a dyno tune.
brandonh06
27
  • Jun 25, 2007
do u know how much dyno tunes usually run?
L
Lookin4Stang
  • Jun 25, 2007
+1 You are better off putting the car on a dyno and getting it dialed in. A mail order tune is what it is and can't be simply adjusted as does the dyno.
I believe your basic dyno tune runs a couple hundred dollars if i'm not mistaken.
04YELLOWGT
1,135
Indiana
Jun 25, 2007
  • Jun 25, 2007
Around here a dyno tune is around $400 for your fist tune then if you change anything and need a tune up its $100-$200.
I have cams in my car and it dies every once in awhile even with my custom tune
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 26, 2007
  • Jun 26, 2007
I do not think it is IAC I think he needs a real tune as has been said.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jun 26, 2007
#10
  • Jun 26, 2007
  • #10
Depending on where you are but since you already have the tuner you should be able to get a tune for 100-150.
Flash it back to stock and see if the symptoms go away.
the98stang
2,408
Clovis, CA
Jun 26, 2007
#11
  • Jun 26, 2007
  • #11
Buy the SCT pro racer package for $400. You'll never need a shop again. It is very easy to use, and you can work with tons of parameters. Plus the tune is more realisitc, because it considers weather conditions and other factors.
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
L
Fox 88 Gt will not idle
  • Leeroy05
  • Feb 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 2, 2025
AeroCoupe
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
