Car Dosent Start Help!
Thanks for the help guys, i went to discount auto, they checked my battery and alternator. The alternator was fine but the battery was gone. I still had a warrenty so they gave me a new one for 5 bucks! Price went up since the last time we got it, but hey 5 bucks i cant complain. Thanks for the help guys, now i have to figure out why my passenger window dosent roll up :bang:
ahh very nice.. good price :nice:. about the window it can be your window motor mine took a **** and i had to get another one
ahh 80 bucks on 50resto, anyway to get it up untill then? Rain is starting to come and i so scared that my car will get soaked, can i push it up if i take off the door panel??
yea take out the door panel and while you're at ir check and see that all the connections are connected and try to roll the window up with the button if nothing check and see if hte motor has power and works
alright thanks im gonna get started on that this second, cause i have to leave my car out at school and i dont want to have to be worrying about rain for 5 hours, if i check the connections and it still dosent work does that mean its the motor? or could it be something else? I guess ill have to push that beast up, isnt it going to be really hard to push up? ahh im gonna get started i supose
I just searched you think it could be a short? Both buttons dont work so idk. I dont really want to spend 80 bucks :shrug:
yea it can also be a short. best way to find out if its the motor or not is to test it out and see if it gets power or not. :nice:
How do i check if the motor is gettiing power? I just took off the panel and i cant even see the motor. And i havent really tried but idk if im gonna be able to push the window up, there was one connector that was loose cause its broken but i connected it again and taped it but still dosent work. Maybe i should make a new thread?
heres what the motor looks like
i think the way my dad triend it was by running a wire to the wire on the motor to a battery. yea make anothre thread im sure u can get more help there
k ill do that thanks, i have a digital multimeter but i have no clue wher to put it, im just gonna try and push it up for now, i need to have this window up. Is it possbile to push it? Thanks man.
i think it is possible but i really dont know. i remember when mine wasnt working i taped it with big bags and tape until i got my new motor. :( good luck though
if you want to push it up you have to take the motor out, its only 3 bolts. with the motor out it is very easy to push up by hand and the clock spring will hold it up. while you have to motor out check to see if it works by jumping it with a drill battery and 2 wires. if it does check the resistance of the motor if it is to great it will not work.
What MustangJoe said sounds right to me. Just to get the window up (as was said), just undo the window motor bolts (3 bolts - around 1/2" heads or smaller, IIRC). then you can move the motor slightly to disengage the motor gear from the regulator. THen slide the window up by hand and mesh the motor gear with the reg and bolt the motor back up. I would have a helper hold the window - My window wanted to fall IIRC and was fairly heavy (cant hurt to have someone hold it, even if the person's assistance was not needed. Windows slamming down sucks). (Note, I am speaking from experience working on a vert - not sure if the window guts are a lot different).
And good advice on troubleshooting it. Dont forget about bad switch connections or bad switch contacts.
Good luck and nice work with the battery. Had you known about the cheapo warranty swap, you could have swapped the battery about 3 pages ago. :D :nice:
alright thanks guys, it was easier than i thought, i just had to know what i was looking at, i managed to get the motor off and highered the window, i bolted the motor back up but im not sure if its on the gear, im pretty sure it is, i tried pushing the window down to make sure it wouldnt move, it rolls down about an inch and then wont go anymore by force so you guys think its good? im just gonna leave it like that till i can find someone to fix it for me. Thanks alot for the help guys, i appreciate it, especially since its suposed to rain tomorrow :shock:
