  • SN95 4.6L Mustang Tech
Car just stopped pulling...
  • Thread starter Thread starter AmBo
  • Start date Start date Mar 2, 2007
AmBo
1,027
New Jersey
Mar 2, 2007
  • Mar 2, 2007
Was crusing to work @60mph, ~2,000 rpms on the highway. All the sudden, it stopped pulling for about a full second. No sputtering, no lights flickering, just stopped pulling. Motor stayed at 2,000 rpms perfectly. Then it started pulling again and didn't happen again for the rest of my commute.
Sound like a bad fuel pump? Belt slip? Mind you, it is raining and pretty nasty here this morning.
AmBo
1,027
New Jersey
Mar 2, 2007
  • Mar 2, 2007
I read it could be bad plugs or a bad fuel filter. Both of which are overdue for a change. I'm having those changed out the 17th so I'll drive like a big vagina until then
DTNODYA
831
  • Mar 2, 2007
+1 for the fuel filter ...
RedDaemon
3,470
9
108
Atlanta, GA
Mar 2, 2007
  • Mar 2, 2007
i actually LOLd
let us know how it runs after the changes
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Mar 2, 2007
  • Mar 2, 2007
I doubt it's fuel filter or pump related, or else it would do it all the time under any kind of load. I bet you 5 bucks that you were sucking in enough moisture to get the MAF sensor elements moist. That would excessively cool them and fool the PCM into thinking there was a bunch more air coming in. The PCM will then add a bunch of fuel and the car will fall on it's face. As soon as the moisture is burned off the MAF sensor elements, the fuel trims will go back to normal.
DTNODYA
831
  • Mar 3, 2007
Good thinking ... FWIW, one time my IAT sensor went bad and caused my car to cut (sort of) briefly in the acceleration range. It only happened once ... thought I'd throw that out there. You may want to take a look at your MAF and IAT just to see if they are clean ... Ain't gonna hurt ...
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
Dangerous High RPM at stop/ RPM Jump when switching to Neutral then dies.
  • 02torchvert
  • Dec 17, 2023
SN95 4.6L Mustang Tech Jan 3, 2024
Yel2002GTAuto
Y
