Car keeps dieing at idle?
You can try with carb cleaner, but you are better off just getting a new one from autoparts store or from ford(more expensive). Easy to put on.
Assuming that is the problem of course, but if he hasn't replaced it before he is due for a new one anyways.
Badlilstang said:
Is there a way to clean the IAC?
i was having the same problems w/ my IAC, and i heard of a quick fix. take the handle of a large flathead screwdriver and tap the IAC valve a couple times. did it to mine and i have been stall-free for ~ 6 months. saves ~$50 for the part too
Ill give that a try! Probably just knocks the carbon build up off if your lukcy!
