  • 1994 - 1995 Specific Tech
Car pulls randomly...
  • Thread starter Thread starter The Green GT
  • Start date Start date May 29, 2006
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
May 29, 2006
  • May 29, 2006
I was on the interstate last nigt to go to a friends house and I noticed that once I hit like 70, my car starts to pull. But its not normal pulling, its just random, not always the same way pulling. I just got new tires on the back and moved my old ones to the fron so I think that might be the problem. But im not sure. Its like its REALLY hard to controll my car sometimes. It will just randomly start to pull and when i correct it will sometimes pull the other way and make me overcorrect. Its kinda dangerous sometimes.
badstang123
397
Santa Clarita, CA
May 29, 2006
  • May 29, 2006
I have the same thing happen to me. I think your right about it being the tires. When I went to a 275 tire up front I noticed this a lot more than with skinnier tires. Don't know if your problem is the same but mine pulls in weird ways a lot too.
The Green GT
1,269
Louisiana
May 29, 2006
  • May 29, 2006
Well the ones on the front currently are the sme size as the old ones. But the old pnes were worn WEIRD. The outside of the tread was just completely finished abut the middle and inside tread was fine. It was like that on both tires.
1TallMF
955
Montreal
May 29, 2006
  • May 29, 2006
Something's out of whack with your alignment. Get 'er aligned and also check for worn inner/outer tie rod ends
BlackVert
5,589
9
98
Bethesda, MD
May 29, 2006
  • May 29, 2006
is it just that one street or alll the time. some streets have ruts that the wheels get in that cause it to do that
WhiteDevil
2,717
San Diego
May 29, 2006
  • May 29, 2006
Yeah mine does that too. I have heard that worn inner/outer tie rod ends can do it. My makes some loud clunks on full lock turns also associated with worn inner/outer tie rods. So im doing 03 Cobra A-arms, steeda bump steer, and new tie rods. Then alignment, hope that helps cure my problem.
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
J
High idle 2003 Mach 1
  • JohnnyUtah
  • Mar 29, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
JohnnyUtah
J
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
