  • SN95 4.6L Mustang Tech
Car rpms dropping quick
  • Thread starter Thread starter jt98boost
  • Start date Start date Nov 16, 2005
J
jt98boost
167
United States <><>
Nov 16, 2005
  • Nov 16, 2005
My 98 cobra will drop rpms very quick if I shift to neutral while cruising down the road, it will drop to about a 1000rpms surge up to 1400 then back down and die. I have replaced IAC, Throttle body, tps is set on 1.00v, dpfe sensor, I know lot of guys have the problem with the idle hanging between gear shifts, but my problem is the opposite, my rpms drop quick and If I don't go to another gear it will surge once or twice and then die can't hold a steady rpm. Anyone got any ideas????
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 16, 2005
  • Nov 16, 2005
Is it driveable or is the problem too severe?
Could it be the fuel filter? It seems like it is fuel related...
J
jt98boost
167
United States <><>
Nov 16, 2005
  • Nov 16, 2005
I can drive it, just got to be carefull not to leave it in neutral while rolling, or it will surge a couple of times and then die. It ildes fine with the car not moving, but if you get going about 30+mph and put it in neutral it just will not stay at an rpm it will drop and surge then die. I changed the fuel filter about 6000miles ago, it has a new 255 vortech intank pump, a t-rex inline pump, 42lb injectors. The fuel pressure regulator is stock, the car has a vortech supercharger.
J
jt98boost
167
United States <><>
Nov 17, 2005
  • Nov 17, 2005
I have the bosch stock bypass valve, just wondering if that would cause the car to do this, it has been on the car since I purchased it 3 years ago thinking it may have went out?
W
WillDuhhBeast
339
Jacksonville Florida
Nov 17, 2005
  • Nov 17, 2005
Egr?
J
jt98boost
167
United States <><>
Nov 17, 2005
  • Nov 17, 2005
no, already have a new one
W
WillDuhhBeast
339
Nov 17, 2005
  • Nov 17, 2005
Is it throwing any codes?
Usually dropping rpm's has something to do with fuel or the vacuum.
ummm...
idk =x I'll :Zip2:
J
jt98boost
167
United States <><>
Nov 17, 2005
  • Nov 17, 2005
Yes, it has a p0500 speed sensor malfunction, but the speed sensor has been replaced. I can rev the car and at 2000 to 2200rpms it seems to shake/miss and then the check engine light will pop up that code ?
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
  • Gulftown980x
  • Jul 29, 2026
squeak93
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
