SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
Admin Dude
Jan 4, 1985
43,366
21,573
234
Box behind Walmart
This is a work in progress. Please run this checklist when it is applicable to you and provide feedback to help improve it. Feel free to comment with corrections or suggestions or diagrams or pinouts that you think might be useful.
This checklist follows the same logic as the Fox checklist: eliminate problems step by step instead of guessing. Skipping steps wastes time and money.
By "surging idle," I mean an idle that wanders up and down more than ~50 rpm, or one that hangs high and won’t return until key cycle.
Step 1: Pull OBD-II codes
  • Use a proper scanner. Cheap readers often miss pending or manufacturer-specific codes.
  • Always pull codes before replacing parts. Even if CEL is off, there may be stored or pending codes.
  • Write codes down exactly (example: P0171 lean bank 1).
Step 2: Check charging system and grounds
  • Low voltage or weak grounds cause all kinds of idle problems.
  • Battery at rest: 12.4–12.6 V. Running: 13.5–14.5 V.
  • Check alternator under load (lights, A/C on).
  • Verify grounds: battery-to-chassis, chassis-to-block, PCM ground near radiator support.
Step 3: Inspect for vacuum leaks
  • Common leak points on 96–98 4.6L:
    • PCV hoses at back of intake (collapse/crack often).
    • Intake manifold gaskets.
    • Brake booster hose.
  • Smoke test is best. Backup: spray carb cleaner carefully around suspected areas. RPM change = leak.
Step 4: Idle Air Control (IAC)
  • Still used on 96–98 cars (unlike later drive-by-wire).
  • Remove and clean IAC with throttle body or electronics cleaner.
  • Resistance across IAC pins: typically 7–13 ohms. Infinite = failed coil.
  • With IAC unplugged, idle will usually drop or stall — if nothing changes, suspect IAC or wiring.
Step 5: Throttle Body and TPS
  • Clean throttle body blade and bore (carbon buildup makes them stick).
  • TPS voltage: key on/engine off, ~0.6–1.0 V closed, sweep smoothly up to ~4.5 V at WOT.
  • Erratic sweep or stuck voltage = bad TPS.
Step 6: Mass Air Flow (MAF)
  • Dirty MAFs are one of the top causes of surging/hanging idle. Especially if an oiled filter has been used.
  • Remove MAF sensor and spray with MAF cleaner only.
  • Output voltage: ~0.7 V at idle, increases smoothly with RPM.
  • Wiring continuity: MAF signal to PCM should be <2 ohms.
Step 7: Fuel delivery (return-style system)
  • Connect a fuel pressure gauge to Schrader valve on fuel rail.
  • With vacuum line disconnected from regulator: ~39 psi.
  • With vacuum line connected: pressure will drop slightly.
  • If low: check fuel filter, pump, or regulator.
Step 8: EGR / DPFE
  • A sticking EGR valve or failed DPFE sensor can cause rough/surging idle.
  • Codes P0401 (insufficient flow) or P0402 (excessive flow) point here.
  • Apply vacuum with a hand pump at idle: engine should stumble/die. If nothing changes, passages are clogged.
Step 9: Sensors
  • Engine Coolant Temp (ECT) and Intake Air Temp (IAT) both feed idle strategy.
  • ECT failure = hard cold idle, rich/lean issues.
  • IAT failure = skewed trims.
  • Both can be tested via live data on scanner: readings should match ambient/coolant reality.
Step 10: Ignition and misfire
  • Misfires at idle can feel like surge/stumble.
  • Check plugs, wires, and coils.
  • Codes P030x (misfire cylinders) point here.
Step 11: PCM / Tune
  • If you are on a stock car with a handheld tuner or “mail-order” tune, try returning to stock and see if the problem goes away.
  • If you have major aftermarket parts (heads, cams, blower, nitrous, bigger injectors, etc.), do not flash back to stock. Instead, suspect the tune as a possible cause and get with your tuner for revisions or datalogging.
NOTES:
  • Always start with codes. Do not skip.
  • This checklist is specific to 96–98 GT (return-style fuel, IAC still in use).
  • 99+ cars differ (returnless fuel, different EGR behavior, COP ignition).
