B Blakonblak94 New Member Jan 31, 2010 38 0 0 Apr 22, 2010 #1 Apr 22, 2010 #1 This may be a stupid question. But I have a mild cam and the car shakes slightly at idle, is this normal? I dont think it should shake as much as it does, but I could be wrong. Any input?
H Haus Member Jul 20, 2005 408 0 16 Apr 22, 2010 #2 Apr 22, 2010 #2 is it only in gear or does it happen when you have in in park/neutral as well??
B Blakonblak94 New Member Jan 31, 2010 38 0 0 Apr 22, 2010 #3 Apr 22, 2010 #3 Not while driving, sorry should have clarified. Only while sitting at idle.
BigmacK192 New Member Apr 8, 2009 210 0 0 Chicago. Apr 23, 2010 #4 Apr 23, 2010 #4 Like a steady vibration inside? Put something on the dash and it rattles? Mine's like that. While I don't think it's normal (I've got a B-cam), it makes a little sense. Though maybe the motor mounts are weak?
DocG 5th graders > me. They're not bant Sep 25, 2005 8,297 1,358 194 Cincinnati area Apr 23, 2010 #5 Apr 23, 2010 #5 Are they stock motor mounts or solid mounts?
B Blakonblak94 New Member Jan 31, 2010 38 0 0 Apr 23, 2010 #6 Apr 23, 2010 #6 Stock motor mounts, I may just be an optical thing because I can see my MGW shake like a mofo
H Haus Member Jul 20, 2005 408 0 16 Apr 23, 2010 #7 Apr 23, 2010 #7 Blakonblak94 said: Not while driving, sorry should have clarified. Only while sitting at idle. Click to expand... I understand that. so it doesnt shake when the trans is in neutral?? When the car is shaking while idling, does it stop shaking when you put the trans in neutral or does it still shake? 5spd or auto??
B Blakonblak94 New Member Jan 31, 2010 38 0 0 Apr 23, 2010 #8 Apr 23, 2010 #8 5 speed, shakes regardless, I can see the shifter moving in first, neautral, whereever it may be when I'm idling.
f8tlfiveo My wife likes my spool and blow-off valve. Aug 8, 2007 1,585 102 64 Lancaster, PA Apr 23, 2010 #9 Apr 23, 2010 #9 What's it idiling at? I put a e cam in my brothers car and the motor shook around until we adjusted the idle
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 33 129 Apr 23, 2010 #10 Apr 23, 2010 #10 You can run a cylinder balance test so you can see if it's a miss.
B Blakonblak94 New Member Jan 31, 2010 38 0 0 Apr 23, 2010 #11 Apr 23, 2010 #11 Hissn can you remind me how to do said cylinder balance test?
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 33 129 Apr 23, 2010 #12 Apr 23, 2010 #12 EEC-IV Testing - Cylinder Balance Test
