Car shakes when braking?
  • Thread starter Thread starter Jaswir
  • Start date Start date Sep 14, 2005
Jaswir
578
Orlando, FL
Sep 14, 2005
  • Sep 14, 2005
Just got all my tires balanced to see if i could get my car to stop shaking when applying the brake... its just the steering wheel that shakes and not the car... unless it shakes bad... havent had a alignment done in awhile but i dont think that would cause it... anyone have any ideas!?
slow93
406
  • Sep 14, 2005
brake rotors
Mavrick
2,264
Collingwood, ON
Sep 14, 2005
  • Sep 14, 2005
Yep, sounds like your rotors are warped. You could have them turned, but they'd most likely warp again in no time. New rotors should fix your problem.
Jaswir
578
Orlando, FL
Sep 14, 2005
  • Sep 14, 2005
hard to change?
CoupedUp
Banned
Aug 26, 2005
260
Gone Fishing
Sep 14, 2005
  • Sep 14, 2005
slow93 said:
brake rotors
A lot of troubleshooting requires deductive reasoning.
If it does it when you brake, that should lead you to start investigating the brakes.
And like stated above ... your brake rotors (discs) are the problem. Mustang brakes from the factory are inadequate and when you have to use them hard and for an extended period they warp fairly easy.
Good Luck
slow93
406
  • Sep 14, 2005
Jaswir said:
hard to change?
they arent hard to change at all...thats considering you do have a little bit of mechanical knowledge.shouldnt take over and hour or two in the back yard.you could also replace the old wheel bearings while you are in there anyways.
CoupedUp
Banned
Aug 26, 2005
260
Gone Fishing
Sep 14, 2005
  • Sep 14, 2005
Jaswir said:
hard to change?
Only as hard as you want to think it is.
I suggest stopping by your local autoparts store and picking up a repair manual for about $18. All we can do is write how to do it, but the manual will have accompanying pics to guide you.
bubba-dough
1,044
Indiana
Sep 14, 2005
  • Sep 14, 2005
Jaswir said:
hard to change?
Not at all. Very simple. It takes longer getting the tools out and jacking the car up. Good luck.
Btw change the pads too. Its also a good time to replace the wheel bearings and seal.
Mavrick
2,264
Collingwood, ON
Sep 14, 2005
  • Sep 14, 2005
They are not hard to change at all. With the right info (ie a manual or tech article), I wouldn't hesitate to take this job on, as a beginner.
Euphoric306
905
#10
  • Sep 15, 2005
  • #10
yea, itll be good to familiarize yourself with the front suspension/steering and wheel/hub assemblies
i kind of look forward to things breaking on my car, because there's a lot of systems that i really dont know about (how they work, what they look like, which parts are where) and its cool to learn new things
example... id like to take apart a rear end and see how everything fits together and such, but ill wait on that one hehe
almost positive its brake rotors, but if there's no vibration or pulsing in the brake pedal it may also be your outer tir rod ends, but less likely than the brakes
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Sep 15, 2005
#11
  • Sep 15, 2005
  • #11
You MIGHT get lucky and just need to repack your front wheel bearings. More than likely if it is just when you apply the brakes the rotors are probably warped.
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Sep 15, 2005
#12
  • Sep 15, 2005
  • #12
Change the rotors ...
babygurl2000
Jackson, MICHIGAN
Sep 15, 2005
#13
  • Sep 15, 2005
  • #13
how are your brake rotors?
crazypete
All my crevices are greased.
Oct 22, 2004
930
Arlington, MA
Sep 15, 2005
#14
  • Sep 15, 2005
  • #14
I've driven on warped rotors for 3 years and they work just fine. I had chance to regularly reinspect them when doing the tubular front end, the 73mm caliper upgrade, again at the hawk pads and there is no cracking or any reason to suspent they will fail other than a little chirp chirp sound when the brakes are slightly engaged.
I strongly suspent that the rust and scale in the vanes blocks the heat dissipation of the rotor and this causes them to overheat and then warp.
I was kinda hoping the metallic pads would "sand" the rotor back to flat but no dice.
bubba-dough
1,044
Indiana
Sep 15, 2005
#15
  • Sep 15, 2005
  • #15
Man you are lucky. My G/F warped the rotors on her car and finally told me it was making a weird sound and vibrating (I never ride in her car). Anyway I am not sure how long this had went on but when I changed them it had feathered the inside tread on the tires. And after it was fixed the tires had a bad hum in them. We then took it to get new tires and an alignment. The alignment was fine so I know it was the rotors that caused it, plus the tech said that'll do it.
Pod
71
Cambridge, UK
Sep 16, 2005
#16
  • Sep 16, 2005
  • #16
I'm a beginner and I'm going to replace my rotors soon.
I've got the rotors themselves already. I'm also going to order new pads.
What other parts would I need to order?
I've seen bearings and seals mentioned, but no idea on the actual parts I'd need to buy. Anything else? bolts, tools?
Thanks very much for any help.
Mavrick
2,264
Collingwood, ON
Sep 16, 2005
#17
  • Sep 16, 2005
  • #17
You may or may not need new bearings. Each rotor rides on two bearings; an inner, and and outter. If you buy new bearings (i'd recommend it, but it's not always necessary), you may want to purchase a bearing packing tool ($40 maybe). You can pack bearings with grease in your hand, but it's messy. There is also 1 seal on the back of each rotor, which seals the inner bearing. I would highly recommend going ahead and buying new seals, as your old ones are more than likely toast.
You will also need new cotter pins for the spindles.. other than that, it's as simple as swapping pads and rotors. Flushing your braking system with new fluid isn't a bad idea either.
As for the calipers, aslong as the piston retracts OK (with a C clamp or channel locks), all you need to do is service them by lubricating the pins with anti seize. You may want to put some "anti-squeek" stuff on the back of your brake pads as well, but thats optional.
BLKGT
34
North Jackson, Ohio
Sep 16, 2005
#18
  • Sep 16, 2005
  • #18
Brake rotors or a loose strut
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
K
Intense Shaking problem
  • KP_NewEdge
  • Jun 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 11, 2025
gkomo
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
