car shuts off!!
  • Thread starter Thread starter 94mustang0886
  • Start date Start date Jan 10, 2010
9
94mustang0886
14
  • Jan 10, 2010
OMG!! my car is shutting off! so heres the deal. i have a 94 auto base mustang. the problem is is that my gauge for fuel pressure sits at the bottom it only raises when i i hit 50 mph but it barely raises at all. and for past week or so if i let my car sit at a stop light and in D it will stutter and shut off!!!! on top of that my car will not stay on when first started!! i have to start it and rev it to 2000 rpms back and forth for bout 2 or 3 minutes to keep the car on once i do that it will stay on. what is wrong with my car anyone have any ideas?? i bought they car with many problems didint think it would ever be shutting off on me know. if anyone can help please do thanks.!!!!
Big Show 96
81
Louisiana
Jan 14, 2010
  • Jan 14, 2010
Try a good tune up, pcv valve,air & fuel filter, plugs & wires to start.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jan 23, 2010
  • Jan 23, 2010
Does this MY have an Idle Air Controller (IAC)? Sounds like the IAC is not supply enough idle air to keep the motor running when the throttle body butter fly valve is closed.
Disconnect the electrical connector to the IAC. The motor should die or the RPM's drop. Or if there is absolutely no change in symptom with the IAC disconnected, suspect an IAC problem. They fail often enough that the possibility should not be ignored.
MustangLX-5.0
856
Lehigh Acres Fla.
Jan 25, 2010
  • Jan 25, 2010
Ahem....
http://www.stangnet.com/mustang-forums/804833-car-shutting-off.html
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Yesterday at 5:24 PM
Mcmahst
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
93 LX 5.0 - 2,000 rpm misfiring, stuttering, and bogging upon acceleration (videos)
  • dan50
  • Nov 14, 2026
Fox 5.0 Mustang Tech Nov 15, 2026
General karthief
