  • 1994 - 1995 Specific Tech
car started missing
  • Thread starter Thread starter drewzx3
  • Start date Start date May 10, 2006
D
drewzx3
411
Louisiana
May 10, 2006
  • May 10, 2006
Yesterday my car started missing. It misses at idle and wlhen you drive it. Every since I got my chip I was having a problem with the car cutting out every now and then but now it doesnt cut out. When it was cutting out I pulled an EGR code 334 but now it does not pull that code.Spark plugs were replaced about 5 months ago. The car has a month old cap distributor and rotor all from autozone. Where should I start in figuring out my problem?
bill302
2,131
alabama,gadsden
May 10, 2006
  • May 10, 2006
have you pulled the codes since yesterday when it started skipping, if not pull codes and post results.
HISSIN50
34
129
May 10, 2006
  • May 10, 2006
........... and while pulling codes, run a cylinder balance test to narrow down what/which cylinder(s) are acting up.
Good luck.
D
drewzx3
411
Louisiana
May 10, 2006
  • May 10, 2006
Also when I get on the gas pretty hard the tach starts jumping. I am at work right now so I will pull them when I get home.
HISSIN50
34
129
May 10, 2006
  • May 10, 2006
The tach issue, if related, suggests an ignition burp. Narrowing it down between a TFI or coil can be kinda' hit or miss though.
Good luck.
D
drewzx3
411
Louisiana
May 10, 2006
  • May 10, 2006
Well I pulled the same code 334 from the memory codes.
bill302
2,131
alabama,gadsden
May 11, 2006
  • May 11, 2006
it seems you have a problem with either your egr valve or your Egr Valve Position Sensor.
If the pintle position sensor Ford calls it the EVP sensor (egr valve position sensor) is shorted or open, you could have a code set.
If the EGR valve becomes carboned up and does not seat fully, the EVP sensor gives a high reading and a code is set.
If the diaphragm of the EGR valve is bad, then it, too, is flagged.
the EVP sensor (egr valve position sensor) is located at the top of the egr valve click on link for picture of one advance auto parts sells. http://www.partsamerica.com/ProductDetail.aspx?mfrcode=SMP&mfrpartnumber=VP1&parttype=289&ptset=A
D
drewzx3
411
Louisiana
May 11, 2006
  • May 11, 2006
Would that cause it to miss?
D
drewzx3
411
Louisiana
May 11, 2006
  • May 11, 2006
I also pulled code 174.
dstanggt50
1,316
Woodinville, WA
May 11, 2006
#10
  • May 11, 2006
  • #10
I don't think it would cause it to miss, I've been running a bad evp code for a while, and my car seems to run ok. I don't know what 174 is, but maybe clean the maf? I don't know if the problem is chip related, but maybe take that off and see if anything changes.
HISSIN50
34
129
May 11, 2006
#11
  • May 11, 2006
  • #11
174 has to do with low O2 switching frequency.
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
