Check the cycling switch. It is located on the passenger side firewall. It's a black cylinder lookin' thing. Short the switch by connecting both prongs inside the switch with a paper clip. Turn on the AC for a few seconds, and see if the idle stops jumping. DO NOT run the AC longer than a minute like this, or you can screw it all up. If the idle levels out, you need to replace the AC cycling switch.
