Here's my setup: '90 5.0 5-speed, pro-flow maf, 24lb injectors, paxton SN92 blower w/ fmu.
I haven't been through the surging idle checklist, because I don't have much of an idle problem. If that's where I should be looking though, let me know and I'll stop wasting your time here.
The car was working great, then I pulled off the supercharger to do some work to it. I put the stock maf bracket back in with a cone filter on the end of the maf so I could drive the car while the SC is off. I disconnected the battery to clear the computer, and so far the car has been through probably 10 full warmup cycles.
So without the supercharger, when I let off the gas after accelerating or cruising, the car surges once or twice. It is more noticable in higher gears, especially 5th on the freeway. It happens right at the transition between being on the gas and coasting. I checked my TPS voltage, it is .96v. I don't have any disconnected vacuum lines or other leaks that I am aware of.
Also without the supercharger, when I first start the car when it is cold the idle surges a little (nothing too major) for about the first minute, then it is fine after that. I don't know if this is related to the surging when I let off the gas.
Anyone have any ideas of what could be causing this? There is no surging of any type while I am accelerating, just when I let off
The SC should be back on in a few days, maybe that will make the problem magically disappear.
Thanks.
Jeff
Thanks.
Jeff
