  • 2005 - 2009 Specific Tech
Car wobble
  • Thread starter Thread starter Red Pony
  • Start date Start date Feb 11, 2009
R
Red Pony
92
Chicago Area
Feb 11, 2009
  • Feb 11, 2009
Car has a mean wobble (side to side) during mild acceleration (traffic) in first gear, up to about 30 mph, feels like it is coming from the rear of car. I am on original rubber in the rear with about 50k, so it is due for two new tires and balancing, could this be the cause?
Definitely feels like something is not balanced, are there any other parts such as drive shaft, manual trans, or differential causing this?
klaw
343
Calgary, Alberta, Canada
Feb 11, 2009
  • Feb 11, 2009
Out of balance is more of a shake and usually at higher speeds than 30 MPH. Wobble (side-to-side) can be caused by uneven tire wear and/or failed belts where the tire no longer runs true. Do you feel the wobble in the steering wheel or more seat of the pants? You should have this looked at by a tire shop ASAP - although you don't feel it as much (or at all) at higher speeds doesn't mean that there isn't a problem. Obviously, you wouldn't want a tire coming apart at freeway/highway speeds. By any chance have you smacked a curb lately?
SpartaPerformance
2,517
61
89
Long Island NY
Feb 11, 2009
  • Feb 11, 2009
+1. Lower speed wobbles are either out of round tire or rim!
R
Red Pony
92
Chicago Area
Feb 20, 2009
  • Feb 20, 2009
Thanks for the replies, I am replacing the rear tires tonight and will report if issue was resolved.
R
Red Pony
92
Chicago Area
Mar 5, 2009
  • Mar 5, 2009
New Rears
New rear tires did the trick.
Thanks all.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
  • Gulftown980x
  • Jul 29, 2026
squeak93
K
Intense Shaking problem
  • KP_NewEdge
  • Jun 11, 2025
SN95 V6 Mustang Tech Jun 11, 2025
gkomo
