  • SN95 4.6L Mustang Tech
Car Won't Shift
  • Thread starter Thread starter Bond20
  • Start date Start date Nov 19, 2017
Bond20
  • Nov 19, 2017
Throw out bearing went bad. It made a really bad noise and won't shift at all. Replaced the flywheel, clutch, throw out bearing, pilot bearing, and clutch cable. It still won't shift gears. I don’t know if i need to adjust the clutch or if i need to adjust the quadrant. Any insight would be appreciated.
squeak93
2,320
397
164
Joplin, Missouri
Nov 20, 2017
  • Nov 20, 2017
Does it change gears while the car is not running?
Bond20
  • Nov 20, 2017
Yes
squeak93
2,320
397
164
Joplin, Missouri
Nov 20, 2017
  • Nov 20, 2017
Keep adjusting the cable until there is very little slack on the cable and the tob isn't pressing against the clutch fingers.
What cable/quadrant setup are you running?
Bond20
  • Nov 20, 2017
It is just the stock self adjusting one.
Bond20
  • Nov 20, 2017
squeak93
2,320
397
164
Joplin, Missouri
Nov 20, 2017
  • Nov 20, 2017
Buy a maximum motor sports quadrant, cable, fire wall adjuster and try again. Stay away from any of the adjustable aftermarket cables. I've tried about all of them and trust me the MM kit is by far superior and made for the best feeling clutch I've ever used.
Reactions: Neuron
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
