Car Wont Start!! HELP
  • Thread starter Thread starter Funhog
  • Start date Start date Apr 9, 2005
Funhog
219
Alabama
Apr 9, 2005
  • Apr 9, 2005
I went to start my car last night and it wont start. The headlights work and I can hear the fuel pump. There is a clicking noise from the side that the battery is on. Ill turn the key, the fuel pump will go and a "click", I let go of the key and it "clicks" again. I tried to jump it and that wasnt it. The pulleys arent turning at all, but I do not think anything is locked up. I think it is either the starter, the alternator, or the ecu. It could be the celluloid (or however you spell it) isnt connecting. Like it is engaging but not executing. Does anyone have any ideas. Any input is greatly appreciated, thanks.
92 LX
3.55
70mm TB
MAC Headers
Flowmaster o/r h-pipes
c/a/i
T
TheUser
1,859
Springfield, MO
Apr 9, 2005
  • Apr 9, 2005
kinda sounds like the solonoid to me - take a screwdriver and connect both posts of the solonoid together and see if it cranks. Before you do this, make sure it's in neutral w/ the e-brake on, might even chock the tires. The solonoid (as you alluded to) is the thing that the battery goes to one side and then the starter wire is on the other side and it's right next to the battery.
If it does crank, you need a new starter solonoid, which I think are around $15 or so, but I'm not positive.
Good luck.
M
MrDark
  • Apr 9, 2005
Starter solenoid probably
Check the starter solenoid, make sure all the wires are hooked up. I bet your right in that its either the starter or the solenoid. Check your battery voltage first before anything. It should be 12volts+ like 12.40 or something close.
Let us know what you find.
Funhog
219
Alabama
Apr 10, 2005
  • Apr 10, 2005
ill let you guys know...i am checking it tues, i got class all day monday
L
lx2c6
37
  • Apr 12, 2005
if the solenoid doesnt work i had a eec power relay go bad (behind the glove box on the right side (mother f***er to get to its better toi take the right frnt speaker out to access) it wasnt producing enough vpwr (norm 5v) the contacts on the inside of the relay were corroded from years of starting so it would give me power but not enough to start the car (talk about an all day diag for a $4.00 part ) good luck
HISSIN50
34
129
Apr 12, 2005
  • Apr 12, 2005
if it wont even turn over, check the battery, cables, etc. a jump start might help ya out.
good luck.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Apr 12, 2005
  • Apr 12, 2005
Check the grounds as well...mine did break in half when I decided to take a look at it, gave it a soft tug and next thing I knew the cable was no longer attached to the vehicle.
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • brandyn200
  • Jun 20, 2026
AeroCoupe
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
H
Engine 1992 mustang LX starting issue
  • Hdbandit
  • May 25, 2025
Fox 5.0 Mustang Tech May 25, 2025
General karthief
