Car won't start - Help!!
  • Thread starter Thread starter RUSH2112
  • Start date Start date Aug 15, 2006
R
RUSH2112
22
Pittsburgh, PA
Aug 15, 2006
  • Aug 15, 2006
Thursday I drove to work, came home, got the garbage out and packed the truck for a weekend camping trip, went out to the bar for a few beers and some dinner, left the bar and stopped at a MAC machine (note: shut off car here) drove home and parked in the driveway. Went to start the car and back it into the garage and it wont start. It cranks and 'tries' to start, but nothing. Initial thoughts were just like the same symptoms 2 years ago which turned out to be the TMI module and the strator, but I checked it this morning and turned the key and did NOT hear the fuel pump engage (3 second buzzzzz). I want to make sure I try all the stupid things before I drop the gas tank and replace the fuel pump.... Luckily, the gas tank is nearly empty. I do know about the shut-off switch in the trunk. I reset it and the pump is still not kicking on when the key is turned to aux position. There is also a fuel relay switch under the driver’s seat that I need to test as well. There might also be a fuse under the hood or dash that controls the relay or pump. These are all small things I need to check before I end up dropping the gas tank to replace the fuel pump. I also called a friend and he suggested getting a rubber mallet to bang on the tank to 'jar' the fuel pump, but that did not work.
Any suggestions on what kind of fuel pump to put in? I am going to try and tackle this job myself.
If I can find a 255 lph fuel pump for a little more than the 190 lph, then I'll go with the bigger one. My future mods won't warrant it, but it can't hurt right?
HISSIN50
34
129
Aug 15, 2006
  • Aug 15, 2006
Access the FP relay and probe the terminals with the relay in the socket. The control side of the relay consists of a controlled ground from the computer and 12 volts via the EEC relay (which goes through the inertia switch).
See Jrichker's no start checklist for a systematic means of troubleshooting.
Good luck.
bretamo
122
  • Aug 15, 2006
Not sure how much help I can be, but I'd first pull the codes to see if you have a intermittent code that maps to the fuel relay circuit. The codes may tell you something.
Also, I believe that fuel relay on a 93 is under the MAF, and not under the seat. That should make it easier if to find and replace.
I recently replaced that relay, and had to go to NAPA to get it (autozone and discount/advanced autoparts did not have it). Take the actual relay in with you, because they probably don't have it in their computer and will have to look it up in a book.
As for fuel pumps, I went with a 190lph Summit Racing (Warbro) pump. They are all easy to install if you have all the equipment you need (a friend helps too).
Good luck!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 15, 2006
  • Aug 15, 2006
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 30-Jul-2006 to include pip diagnostic help
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. See paragraph 3A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) 86-93 models only: Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Fox Prepping a '91 to start after 5 years sitting?
  • 331strokerGT
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 16, 2026
limp
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
