hi, i put a supercharger,75mm throttle and egr,75mm mass air,30lb injectors,190 fuel pump, a new fuel filter,an ignition modual,new coil,new optima battery, it turns over but wont start....what could be the problem????
Also, make sure that the s/c isn't blowing the spark out. Do you have the correct plugs first, then gapped correctly?? Should be smaller gap than stock and about 2 heat ranges colder plug..
