car wont start
  • Thread starter Thread starter Z06punisha
  • Start date Start date Mar 20, 2006
Z
Z06punisha
  • Mar 20, 2006
Kay guys did a search already but none fit my problem.
Its my friends car and he said he took a really hard turn and he slammed his brakes and his car fishtailed and hit a dip pretty hard and turned off on him.
And thats how the problem started. Now it cranks but wont start.
things weve checked, fuel pump relay, ignition switch, fuel pump, spark.
The motor just turns, gets no spark nor does the fuel pump come on. We got it to start when we give the coil power directly from the battery. That way we do get spark and the fuel pump to come on.
havent messes with the fuel cutt off switch yet, does it have to be pressed?
help please he doesnt want to rig it.
thankx in advace
5.0 con-vert
No soup for you, Joe Rogan!!!
Jun 7, 2005
244
Boca Raton, FL
Mar 20, 2006
  • Mar 20, 2006
The first thing I would do would be to check the Inertia (fuel cut off) switch. Push the button back in and see what happens. What happened to the car sounds like something that would set it off.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 20, 2006
  • Mar 20, 2006
No description of the car, year or mods. He could be driving a go kart and we wouldn't know it.
Just in case the car is an 86-95 fuel injection Mustang 5.0, here's the checklist. Follow it and you will find and fix the problem.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Z
Z06punisha
  • Mar 20, 2006
im sorry guys the car is a 93 5.0 coupe.
"Jrichker" i already went printed out ur list cuase it is real helpful. The only thing i got left to check is the fuel cut/off switch.
HISSIN50
34
129
Mar 20, 2006
  • Mar 20, 2006
shttygtstang
978
  • Mar 20, 2006
its the cut off switch in the trunk
Z
Z06punisha
  • Mar 21, 2006
ok guys, i checked the inertia switch and that wasnt the problem still cranks over and wont start. Still not getting any power to the coil or fuel pump. the button on the inertia switch was pressed in, so i know it wasnt that cutting off the pump. Cause like i said the only way its starts is if i get a wire and connect it to the coil directly from the battery. when i do that, then ill get spark and the gas going. thats when the cars starts right up. One other thing the car isnt charging anymore it reads about 10volts.
What else could i check guys
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 21, 2006
  • Mar 21, 2006
Start at the top of the checklist and work your way down. You will find the problem. It catches 99% of the problems if you don't skip any steps.
Don't throw parts at it in an attempt to fix it. I try to teach people how to troubleshoot problems in a rational manner, thinking about what they see & what they know. Troubleshooting is a skill that transferrs to many other areas other than cars.
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
  • brandyn200
  • Jun 20, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
