car wont turn over
  • Thread starter Thread starter DCjuggalo
  • Start date Start date Jan 19, 2006
DCjuggalo
169
Charlotte, NC
Jan 19, 2006
  • Jan 19, 2006
when i turn the key the rpm needle goes up, but nothing happens what is that?
HISSIN50
34
129
Jan 19, 2006
  • Jan 19, 2006
Year of car? So nothing at all happens? Does the starter interlock circuit kick out the radio, etc?
Absent info, I would look for 12 volts at the end of the s-terminal on the starter interlock circuit.
See Jrichker's no-start checklist.
Good luck.
ironmedic
1,361
Puyallup, WA
Jan 19, 2006
  • Jan 19, 2006
timing could be off pretty bad or u dont have vaccum. u need more details bro
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 20, 2006
  • Jan 20, 2006
Here's a checklist:
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection: more than .5 volts across a connection indicates a problem.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
4.) Then pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems. See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars .OR see http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars. See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) If that doesn't work, use a jumper cable from the positive lead on the battery direct to the starter post where the big wire from the relay connects. If it cranks then, it is the power wire from the relay gone bad. This will be hard to do, since there isn't much room to do it.
8.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
DCjuggalo
169
Charlotte, NC
Jan 20, 2006
  • Jan 20, 2006
thanks jrichker, it started when i jumped the solenoid.. but the thing now is that it wont rev past 3000 rpm, what is that?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 20, 2006
  • Jan 20, 2006
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
I
Innova scanner not working 88 5.0
  • Idkwhatimdoing
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2026
Steverino
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
  • Mindseye007
  • Aug 16, 2026
Mindseye007
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
