carb starting problem
  • Thread starter Thread starter OonDeanisS
  • Start date Start date Feb 4, 2006
OonDeanisS
902
Danbury, CT
Feb 4, 2006
  • Feb 4, 2006
my engine turns over, but doesnt start. It's getting gas, and i believe spark, but the gas is getting blown out the top of the carb like the engine sneezing. It doesnt always happen though, sometimes it sounds like its starting, i can hear the exhaust for a second, then its off again. Whats the deal?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 4, 2006
  • Feb 4, 2006
i would say either you have the wiring wrong (i.e. H.O wired for a non H.O. or other way around) or you have a intake valve sticking open causing there to be pressure to blow gas the wrong way. does the car ever run? perhaps just the fact that it doesn't want to fire so the engine kinda kicks backwards and the fuel isn't getting pulled into the engine.
EMW150
2,020
Roaring Spring,PA
Feb 4, 2006
  • Feb 4, 2006
If it's a pretty heavy cammed engine, and it's cold out they can be real tough to start. Mine is a real pain to start if it's been sitting for a long period and it's 40 degrees or less out. It "sneezes" through the carb like crazy (sometimes catching on fire), and tries to start like you said, you can hear it firing in the exhaust but just won't catch and go. Pump it about 3 or 4 times and then try it. Large duration cams have trouble because at low rpms they are very inefficient at pulling the mixture into the cylinder and the cold air makes it alot worse.
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Feb 4, 2006
  • Feb 4, 2006
Agree'd, lots of overlap can cause a car to be hell to start when its cold.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 4, 2006
  • Feb 4, 2006
i had to back my dizzy off to get my car to start the other day. you may have to do that and then put the timing back in once its warmed up and idling.
9
90_306powerhous
  • Feb 4, 2006
if gas is coming out of the top of the carb i'm gonna guess the floats need adjusted. i'm not a carb expert so it could be anything. also what kind of carb do u have?
OonDeanisS
902
Danbury, CT
Feb 4, 2006
  • Feb 4, 2006
i also noticed that my fuel pump shuts off when i turn the key to start, and comes back on when i turn it back to on. would this cause it?
OonDeanisS
902
Danbury, CT
Feb 4, 2006
  • Feb 4, 2006
its a holley 750, and it was rebuilt during a dyno-tune a few months back, so the floats should be fine.
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
SN95 V6 Mustang Tech Mar 20, 2026
