1.) What I understand is that the 19s will handle up to 300hp, then you pretty much need 24s.
2.) I also understand that the stock MAF setup will run 24s without issue,
Dont get the holley because no one on here would be able to help because o one has done it i know because i was gonna go with a motec system but didnt
You should start a new thread, or do a search.alright so im fixing to carb swap my 88 foxbody i already got the stuff i need so i believe. (holley 650 4brl, intake, gt40p heads, hei vaccuum advance distrib.) i just ordered a 296/302 dur. .520lift cam and .525 max lift springs. planning on reusing stock roller lifters, rockers and pushrods. will i run into any clearance issues? planning on using my electric fuel pump just put a regulator on it. theoretically it shouldnt need anything else so i think i could be completely wrong. i need someones help who has done this before. thank you
2.) No it won't. The stock MAF should be paired to stock injectors.
So then you can run any injector with a stock MAF if you just tune the ECM?With a different ECU...
93-95 Cobras ran 24s with the same MAF as the GT counterparts.
1.) So then you can run any injector with a stock MAF if you just tune the ECM?
2.) Why would anyone ever bother to buy (or manufacture) calibrated MAFs if that is the case?
