Carbon Monoxide?
  • Thread starter Thread starter Dbeck002
  • Start date Start date Nov 14, 2005
Dbeck002
710
South florida
Nov 14, 2005
  • Nov 14, 2005
Mods are H/C/I and dyno tune.
Long tubes, no cats.
At idle the car will smell like a semi trailer. It floods the area with scent of exhaust fumes in seconds.
Am I in any real danger? I think it gives me a headache but it could be psychological. If i roll up the windows and turn on the AC i wont smell it but then again i cant smell CO. I am just worried, health first.
dw89lx
44
Boston, MA
Nov 14, 2005
  • Nov 14, 2005
My car smells relly strong too. I used to get headaches when I first bought the car but I don't anymore. I'm not sure if there are any real dangers though. I usually drive with the windows open to keep fresh air flowing inside. I'm sure you'll be fine.
HISSIN50
34
129
Nov 14, 2005
  • Nov 14, 2005
Well yeah, CO is odorless. But getting a headache from exhaust fumes is normal for me. It is your body's way of telling you not to breathe that stuff in.
Do you have dumps or something? The lack of cats certainly does not help, nor does idling in the garage or any enclosed space.
Good luck and be safe!
Dbeck002
710
South florida
Nov 14, 2005
  • Nov 14, 2005
when i never idle it in my garage or said i did.. but even out in the open within seconds everyone within a 30 foot radius can smell raw exhaust. I thought of lowering my FP but i know it wont matter because the pulsation of the injectors will keep the same amount of fuel flowing if pressure is decreased, hence problem unsolved. I dont know what to do, its really strong.
R
rowdie- stang
172
augusta ga
Nov 15, 2005
  • Nov 15, 2005
If you have a blow through mass air like a c & l you can rotate it toward the motor a little and it will lean out at idle, turn away from motor and it will riching. Put some high flow cats on and the smell will get better
HISSIN50
34
129
Nov 15, 2005
  • Nov 15, 2005
Didnt mean to imply that you do idle the car in an enclosed space. Only to say that it was to be expected in that situation. But out in the open, that is a little strange.
Dbeck002
710
South florida
Nov 15, 2005
  • Nov 15, 2005
oh ok gotcha.
I dont wanna get a new H pipe because than ill need to re-install my smog pump so the cats wont get clogged after long term use. I wish there was a way i could solve this.
blackcloud50
388
  • Nov 15, 2005
You are most likely smelling excessive HCs (hydrocarbons). What does your set up consist of? What are cam specs, injector size, etc.
18mustangs
533
Virginia Beach, VA
Nov 15, 2005
  • Nov 15, 2005
You've got that backwards, towards to motor fattens up the mixture as it sees more air flow, towards to fender leans it as it sees less air. 2 issues ago of MM&FF or 5.0 Mustang showed that with a dyno tune.
Tim
Dbeck002
710
South florida
Nov 15, 2005
#10
  • Nov 15, 2005
  • #10
Heads are AFR165s
Cam is 221/225 @ 0.05"
0.499"/0.512" lift
24 lbs injectors
It was dynoed and tuned to a 12.8:1 A/F steady
It just smells really strong at idle. Could it be the 93 octane.
blackcloud50
388
#11
  • Nov 16, 2005
  • #11
Dbeck002 said:
Heads are AFR165s
0.499"/0.512" lift
24 lbs injectors
OK....I read your list of mods from your link. I suppose it is all updated.
1. Fuel pressure is at 42# with vac line off or on?
2. What is your TPS voltage set at?
3. Are you using an add on chip/tuning device or the stock ecm?
Have you taken your car to get your exhaust gases analyzed (an emissions testing facility..go to a private shop to have them put it on the machine in "test" mode) to see what amounts of HC, CO2, CO, and NOx. This can sometimes help figure out where the issue is.
I have this same issue so I know exactly what you are talking about with horrid smell. Cats will clear it up for sure but in my case I had my exhaust gases checked to find that I have excessive amounts of HCs (unburned fuel) causing the smell. If I put the cats on, smell is totally gone but cats overheat like mad. So I have to get the HC issue under control somewhat b4 I put cats back on or I just will ruin them. I haven't figured why I have high hydrocarbons at idle yet but I am working on it. My set up is a little different than yours but nevertheless sounds like the same problem.
Did you have offroad h- pipe on and smog pump bypassed prior to cam and head swap? At that time did your exhaust smell reasonable?
blackcloud50
388
#12
  • Nov 27, 2005
  • #12
Any update?
Dbeck002
710
South florida
Nov 27, 2005
#13
  • Nov 27, 2005
  • #13
Nothing yet. Im going to try rotating the MAF as previously mentioned.
And my fuel pressure is actually a lot less than 42#. when the car was dyno tuned the fuel pressure was turned down to like 34-35 with the line off.
Thanks for all the help.
SOLD 1993 Mustang Cobra / 114K miles / Modified / Fort Lauderdale, Florida.
  • Naja
  • Oct 4, 2023
12K
Fox Body Mustangs For Sale (1979-93) Feb 26, 2025
Naja
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
Cat Delete Questions V6
  • Israel Salinas
  • Jan 18, 2016
1996 - 2004 SN95 Mustang -General/Talk- Jan 18, 2016
B.erazo712
T
600+hp Gear Ratio And Rpm Help
  • TomasV
  • Apr 10, 2016
4K
2005 - 2014 S-197 Mustang -General/Talk- Apr 11, 2016
TomasV
T
C
  • Locked
SOLD 1988 Mustang Gt Hatchback $4,700
  • Chuck6017
  • Mar 2, 2016
2K
Fox Body Mustangs For Sale (1979-93) Mar 7, 2016
Chuck6017
C
