Carpet glue
JD1964
there is enough sticking out to grab on to
3,606
1,614
194
Maryland
We’re sizing and trimming new carpet for the convertible. Going good so far. Obviously I’ll need some adhesive here and there for a nice tight job. What is the best user friendly product for this task?
Molded carpet isn't supposed to be glued. Custom shops would glue a "cut and sewn" job to keep it in place and keep it looking good, but that won't be necessary ( in any place) with a molded set like you pictured.
Thanks everyone. It’s actually setting in pretty good without any adhesive. I might try the carpet tape idea in a few spots. One in particular at the back of the console where I slipped and the knife cut longer than I wanted. Most of that will be hidden when the console is in but there still a small slice I’d like to hold in place.
I did get some spray on adhesive I’ll use for map panels, carpet pieces that go on rear side panels and plastic and insulation that’s on the inside of the doors.
I got to painting the interior parts. Got a bit worried because the finish was splotchy. No matter how many coats I put on, splotchy! Followed all the instructions too.
Then I solved the dilemma. VHT matte clear as the final coat. That eliminates the splotchy look and oddly darkens the final a slight bit. In these pictures you’ll see the splotchy part next to the ones with matte clear as a final touch.
