carpet, where to get?
Daggar said:
Did you catch the response I got from Texas on this Sureshot?
Yea just got done reading it, thank you Sir. :nice: Looks like another thing to add to the order. I want to delete the center console and just have the shifter and e-brake visable. Should look sharp...
I wonder if it would be possible to relocate the E-Brake to under the dash. Rig up some sort of short pedal down there and a hand release. That'd be sweet. I'll have to crawl up under there and see if there's any room for something like that.
Let me know what you find out, you will need some more cable and a pulley or two. Im going to rig mine up to a toggle switch on the dash....lol
sirsureshot39 said:
What wp did you order? Got a link to both of those things you just mentioned?
WP
http://www.meziere.com/index.php?pgName=wp311
329.95 at bmrfabrication.com
Alt kit
Moroso part number 63810 is a low mount alternator bracket that can be used on either side.
105 bucks via summit.
Just switched my carpet in my hatchback. I bought it from Dallas Mustangs. ACC Carpet. It is a lot lighter than Stock. There were no holes precut. The best way to do it is take your old carpet and put it on over your new one and then make the holes for the shifter and ebrake. Pretty easy to do but it takes some time. Don't make the cut out as big as the ones from factory. You can always make them bigger later.
gooch06 - Good thoughts...
I was going to get new ACC carpet but I seem to have researched into some quality issues with it on how it lacked compared to the OEM carpet so I opted to remove the carpet and spins some money and elbow grease at the car wash (high pressure washer) and made it look much nicer and still had the OEM quality.
Just a FYI but when the sound deadening and carpet get soaked with water it is kind of heavy:D
