  • SN95 4.6L Mustang Tech
caster camber toe...
  • Thread starter Thread starter US muscle
  • Start date Start date Apr 5, 2005
US muscle
  • Apr 5, 2005
I lowered my mustang ( little over an inch) and i'm bringing it in for an alignment. What are some optimal caster camber and toe numbers which will give me good tire wear but still have adequate cornering stability? Ford sets it at -.5 camber, + 3.2 caster, and + .25 toe stock... should i go with a little more negative camber for better handling -.8? Or keep it the way ford says..
Jones331
Banned
Oct 2, 2004
142
Oakland CA
Apr 5, 2005
  • Apr 5, 2005
Tell them you want your caster at 6 degrese and youre camber at NEGITVE 1.1-1.2 and factory toe specs at 3/32nds TOTAL TOE IN ........youre welcome in advance.............jj
Thundermouse
168
Decatur, GA
Apr 5, 2005
  • Apr 5, 2005
did you get new caster and camber plates? if not you're pretty much stuck with whatever caster you have.
W
Will Smith
191
Cape Coral, FL
Apr 5, 2005
  • Apr 5, 2005
u can't change the rear that much. but as for the front I would get the TOE to be as close to zero on both sides. as far as caster goes i would just make sure that ur wheels are in the middle of the wheel wells and that they are both even in front. as for caster I have mine set i believe its a positive camber which is when the lower part of the tire is sticking out more than the top but not too much. that should improve your cornering and your lessen the outside tire wear when u corner.
MadonnaRioRedGT
41
Houston/Waco, Texas and Colorado Springs, Colorado
Apr 6, 2005
  • Apr 6, 2005
Like said before...
Unless you have aftermarket fully adjustable caster/camber plates, your caster is NON-ADJUSTABLE.
As far as your camber and toe, it is best to keep your alignment fairly close to the stock specifications. You could requestion a slight increase in negative camber if you like for the front tires, such as -0.8 total camber, for a bit better negotiation and handling of turns.
- Brian
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
