  • SN95 4.6L Mustang Tech
Caster/camber ?
  • Thread starter Thread starter stang_man_1
  • Start date Start date Mar 2, 2006
stang_man_1
24
  • Mar 2, 2006
Any Alignment gurus out there maybe you could help me.
Just got my ffrp Caster/Camber plates. The actual labor isn't a problem but i'm not sure where to put the spacers or which set of slots to put over the studs from the bottom plate.
Any help would be appreciated.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 2, 2006
  • Mar 2, 2006
Didn't they come with easy to understand instructions like the Maximum Motorsport ones do?
stang_man_1
24
  • Mar 2, 2006
They came with instructions but there is stuff i don't know. for instance i,m not sure how low my car is and i don't know which set of slots to use.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 2, 2006
  • Mar 2, 2006
What springs do you mean when you say "upgraded springs"?
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 2, 2006
  • Mar 2, 2006
send them back and get some M/M plates!!!!!! i'm an alignment tech and i HATE messing with any plates other than M/M!!! IMO all the others are JUNK!!
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 2, 2006
  • Mar 2, 2006
I also think you should get the MM ones.
stang_man_1
24
  • Mar 2, 2006
I'm not sure. I bought the car used and they were already done.
I really need to use these plates too because I kinda need to get them installed pretty quick.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 2, 2006
  • Mar 2, 2006
well good luck with it. i have seen a lot of aftermarket plates that wont breing the align back into spec. heres a little trick that most people on here have never heard about. you can use an 18mm cam bolt to bring the camber in or out almost 3/4 a degree in addition the the adjustment in your plates! the great thing is that the cam bolts are less than $40 and they just install in place of your regular strut bolts!!i still strongly urge you to return those plates while you still can. another week wont wear your tires that much. trust me you will regret not going with the M/M plates. oh yea if your worried aboput your tire wear tell the tech to set your camber at about -0.3 degrees and the toe to +0.32. hope this helps
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 3, 2006
  • Mar 3, 2006
return them and get the MM ones.
Back2Mustangs
466
#10
  • Mar 3, 2006
  • #10
I went with the four-bolt CC plates from UPR. Did the install myself as I do with everything else, and It was breeze. I even used the MM online instructions for reference: http://www.maximummotorsports.com/instructions/MMCC9994v4r4.pdf
Those should help you alot.
the98stang
2,408
Clovis, CA
Mar 3, 2006
#11
  • Mar 3, 2006
  • #11
MM CC plates > any other CC plates
Although FRPP is a good name to stick to
twogts4us
4,188
12
79
Dunedin, FL
Mar 3, 2006
#12
  • Mar 3, 2006
  • #12
Ordered my MM CC plates last week (via EBay, saved $10 bucks over MM's list price, plus free shipping - and they are still shipped directly from MM (so I know I am not getting MM knock-offs).
I also wouldn't worry about substantial wear, unless you dropped it into the weeds. I've got some decent neg camber going on and it's been this way for about a month...ok, agreed, it's about time, but it's not going to chew your tires apart in a couple days.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
