cats smoking
  • Thread starter Thread starter 86mustang5.oh
  • Start date Start date Jul 25, 2005
86mustang5.oh
125
battle creek mi.
Jul 25, 2005
  • Jul 25, 2005
if i let my enginve run for about 15 min or if i drove it for that long smoke will start coming out my hood and i found it coming from the forst cat on my exaust its still stock exausht but does any one know why it does this
crazypete
All my crevices are greased.
Oct 22, 2004
930
Arlington, MA
Jul 25, 2005
  • Jul 25, 2005
Either:
1. You're running super rich on one side and this causes the converter to heat the heck up in a hurry
or..more likely
2. You're seeping oil down the exhaust pipe.
86mustang5.oh
125
battle creek mi.
Jul 25, 2005
  • Jul 25, 2005
i kinda smells like oil any ideas how that is happening
crazypete
Oct 22, 2004
930
Arlington, MA
Jul 25, 2005
  • Jul 25, 2005
Either your PCV is blocked and the oil is being squeezed out of the seals or the rear main seal is leaking. Unscrew the oil filler cap and put a dryer sheet over it with a rubber band so crap doesnt fall down into the valve cover and see if after a few warmup cycles it stops smoking. If so, get a push-in breather for the filler stem and you're all set.
89lxsport50
550
Franklin Tennessee
Jul 25, 2005
  • Jul 25, 2005
Are the valve covers leaking?
86mustang5.oh
125
battle creek mi.
Jul 25, 2005
  • Jul 25, 2005
well if you look at it from the front of the car it is on the rightside of the motor and there is much of anything i`l have to look i geuss
86mustang5.oh
125
battle creek mi.
Jul 25, 2005
  • Jul 25, 2005
and there is no oil cap or anything on that side
86mustang5.oh
125
battle creek mi.
Jul 25, 2005
  • Jul 25, 2005
valve covers ar not leaking
18mustangs
533
Virginia Beach, VA
Jul 25, 2005
  • Jul 25, 2005
Or maybe he could just replace the PCV filter, grommet and valve and let the system work as it's suppossed to. That'd be about $20 total from 50resto.com One should never run a breather cap on a closed PCV system.
86mustang5.oh
125
battle creek mi.
Jul 25, 2005
#10
  • Jul 25, 2005
  • #10
welll i had my dad check it out and well we figured ou t its a exhaust leak off my header and conveinced my mom to get full length .....yay no my stock
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jul 25, 2005
#11
  • Jul 25, 2005
  • #11
Is your car automatic?? does it have a tranny leak???
My old 2.3 stang auto used to leak and while driving the fluid would drip on the cats and smoke, it smelt also....
kornchild4life
46
islip, ny
Jul 25, 2005
#12
  • Jul 25, 2005
  • #12
Take a look at the oil pan too, make sure the gasket there is all good. I'm having the same problem with the smoke off the cats and exhaust and i think my oil pan gasket is shot...hope im not wrong
86mustang5.oh
125
battle creek mi.
Jul 25, 2005
#13
  • Jul 25, 2005
  • #13
no i got a t-5 but yea there is too much oil in my car i cheacekd that gonan have to drain some tomoorw
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
