  • SN95 4.6L Mustang Tech
ccrm issues
  • Thread starter Thread starter weld
  • Start date Start date Jun 4, 2010
W
weld
  • Jun 4, 2010
just got a 02 gt and a/c compressor was not cycling on. bypass low pressure switch and nothing. gauges read a/c coolant is full. all fuses are good. took off ccrm under fenderwell on passenger side, opended it up and one of the pins on the a/c relay was burnt. took a a/c relay off the ccrm from a 98 ford escort which read the same numbers on them as the mustang. i solder the used a/c relay from the escort to the mustangs ccrm. put it back on and a/c clutch still did not engaged. my first time doing this so not sure if i did a good job on the contact on the solder. Now when i first started the car after the solder and found out the a/c compressor still dont kick in, I come to find out the car wont turn off now when i completely turn the key off and all the way out. Could i have affected another relay by tryin to mess with the ac relay on the ccrm. I just need the car to turn off with the key for now and ill be back to square one. im a newb to this so any input will help thks...
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 4, 2010
  • Jun 4, 2010
Sounds like you already know the answer.
If one pin was burnt, likely others were affected as well. Or perhaps, there is a solder bridge from the repair.
Not sure that I can offer any addtional advice beyond what you already know.
Get a new CCRM.
BWD RCM12M - Relay Module | O'Reilly Auto Parts
W
weld
  • Jun 5, 2010
considering what ive done will it cause the car not to turn off anymore with the key? All the light on the dash turn off with the key but the car just keeps runing. I have to stall it out in first gear for the car to turn off.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 5, 2010
  • Jun 5, 2010
Question? Did it turn off before the home repair was done? Was any other work done at the same time?
The primary purpose of the CCRM is to act as the MAIN power relay. So why is it so hard to believe that a solder bridge is keeping a relay engergized.
Further consider the circumstance. You actually found burnt pins and foil traces. How much more do you need?
Sooo unless you are prepared to perform a full funcationality of the old part, I'm not sure you are going to get a definative answer from someone in Internet land.
W
weld
  • Jun 10, 2010
Are there any ccrm's that are interchangeable with different year stangs?
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 11, 2010
  • Jun 11, 2010
Try this. Go to:
Home Page | O'Reilly Auto Parts
Enter the car's information. Search for CCRM. It should bring up several products. For the cheapest go to "Cardone - Relay Control Module Part Number: 73-70020".
Click on the compatibilty tab. There is a list of all the other MY's the part will fit.
sneaky98gt
2,387
144
114
NC State University
Jun 11, 2010
  • Jun 11, 2010
My CCRM went out this past week as well. I got the A1Cardone brand CCRM from O'Reilly (the one wmburns pointed out) and got it put in last night. It is working fine so far. And it has a 1 year warranty.
W
weld
  • Jun 16, 2010
just thought id share why my car was not turning off with the key. since i did mess with the ccrm trying to solder on a used a/c relay it obviously messed up something. but long stroy short i disconnected the a/c fuse under the hood and now the car turns off with the key. ill just sweat it out for now until i have some cushion money to buy a new ccrm. thks for the feed back guys
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jun 17, 2010
  • Jun 17, 2010
I have a used one if needed. Save you some cash. PM me for details.
soupnutz
73
Hampton Roads, VA
Jun 17, 2010
#10
  • Jun 17, 2010
  • #10
I did some shade tree **** to my car, was having the same problem, so I bypassed the ccrm a/c wise and ran the wire coming of the pressure switch right to the a/c compressor. Not 100% but from looking at the schematic it appeared the only thing the CCRM did for the a/c was shut it off at WOT, been 2 years and no issues yet.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 18, 2010
#11
  • Jun 18, 2010
  • #11
So don't you think this confirms a solder bridge between the AC circuit and the ignition circuit? Otherwise, pulling the AC fuse wouldn't by-pass the problem.
Have you tried going to a salvage yard? Try car-part.com for a searchable list of salvage yards.
D
DrYeRLiNt
32
#12
  • Jun 18, 2010
  • #12
If it will work I have a ccrm off of a 98 gt id sell
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
