Ccrm No Power To Fuel Pump
hlpnktzjr
Can any one help me? Im having problems with a 95 gt getting power from the ccrm to the fuel pump. All fuses are good tried two new ccrms and even a different pcm but the problem is always the same. Have power into the ccrm but nothing out to the I/s. Also cooling fan runs as soon as the key is turned on. I can shoot a ground to the Lb/o wire that is from the ccrm to the dlc to the pcm and it triggers the pump. Any thoughts?
I had a problem with my CCRM when I first got my car, I'm 2nd owner. The CCRM is one of Ford's WORST ideas because it takes critical relays and seals them into the little, black box. Your fan coming on is a symptom that the relay inside the CCRM has failed in the open position (assuming all other connections/variables are right).
As far as the fuel pump issue: its most likely the CCRM again. It can be opened and all relays can be replaced, but you can also get rebuilt ones from eBay (where I got mine). The main issue w/a replacement is that it [must] be an [exact] match of your old one. The part numbers [must] match as well as the letter code (e.g., J, L, M, etc). Yes, ppl have gotten CCRMs to work w/o an exact match, but you are asking for problems -maybe right away, maybe in a few months, maybe in a couple of years, but it will give problems if not matched.
If you are interested in my source on eBay let me know and I'll dig it up. If you are good w/electrical repairs just fix your original one w/exact replacement components.
94-95 CCRM wiring
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
94 & 95 Mustang Electrical and Vacuum diagrams.
94 & 95 Mustang 5.0 1994-1995 CCRM AC schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-CCRM-AC-Diagram.gif
9& 95 Mustang 5.0 1994-1995 CCRM AC Part2 schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-CCRM-AC-Diagram-2.gif
94 & 95 Mustang 5.0 1994-1995 CCRM PCM Transmission schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-CCRM-PCM-Transmission.gif
94 & 95 Mustang 1994-1995 Engine Fuses Door Controls schematic, in color, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-Eng-Fuses-Door-Controls.gif
94 & 95 Mustang 5.0 1994-1995 Exterior Lighting schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-Exterior-Lighting.gif
94 & 95 Mustang 5.0 1994-1995 Fuse Box schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-Fuse-Box.gif
94 & 95 Mustang 5.0 1994-1995 instrument cluster schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-instrument-cluster.gif
94 & 95 Mustang 1994-1995 Underhood Fuses schematic, in color, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-Underhood-Fuses.gif
94 & 95 Mustang 5.0 1994-1995 Ignition Control Module schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-IgnitionControlModule.gif
94 & 95 Mustang 5.0 1994-1995 Alternator schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-Alt.gif
94 & 95 Mustang 5.0 1994-1995 Head Light schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-Head-Light.gif
94 & 95 Mustang 1994-1995 Air Conditioning schematic, in color, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-AC.gif
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
