Cd Player Does Not Work
mike2858
1,456
West Long Branch Jersey.
my cd player will not work at all (it is the stock mach 460) its not the common will not eject cd problem. i dunno whats wrong-i went to switch cd slots and there is like this hissing/sizzling kinda noise. nothing ejects-nothing plays. the radio still works though :rolleyes: any idea on what could be wrong? tom. im gonna go hold the eject button because that is supposed to eject them all instead of selecting each 1 individually :mad: :mad:
Is it really cold there right now? Did you wait for your car to warm up? I had the same problem the other day when it was about 30 degrees, my player wouldn't eject anything until my car was warm enough on the inside to heat up the player, then it works as normal. Good luck.
mike2858 said:
it was like 40- i dunno i tried it, drove about 10 minutes, tried it again and nothing. il try it tommorrow.
If your car is a 2002 you should be covered under the warranty. I just had my mach 460 replaced in my 2001 under the factory warranty for a similar problem.
Just had mine replaced about 2 weeks ago. It had CDs in slots 1 and 2 but said they were empty, but when you tried to load into either of those slots it would hang up and give the CD error message.
