Hello all,
I just installed this kit CDC Quad Fog Light Kit for 99-04. The set up uses 2 wiring harnesses, each with its own little switch, wiring, and relays. I set up one set of lamps (one set is white, one set is yellow) and used my existing wiring harness.
I took the old bulbs, soldered new ends of the pins, and plugged the parts back into my original harness. It works ok for one pair.
My problem... I want to use the second set of lamps, but I dont want a tacky switch hanging around. I have a 2000 GT convertible.
I was hoping to install another factory switch in my console, but there is no room to put one in. Suggestions? Thanks
