  • 1994 - 1995 Specific Tech
change the fuel pump?
  • Thread starter Thread starter tsoccer3299
  • Start date Start date Nov 15, 2005
tsoccer3299
255
Tacoma
Nov 15, 2005
  • Nov 15, 2005
ok so my car for awhile now had trouble starting when it was cold, now it seems to happen every once in awhile when it is a little warm too. It just cranks over but wont fire up. I'm kinda limited in what I can do since I'm here at college. I've changed the ect sensor, fuel filter, cleaned the iat, iac, and maf sensors and no luck. When I put the key in the on position I can hear the fuel pump prime like normal, sometimes i will sit there and prime it quite a few times and it seems like this makes a difference. I know I should buy a fuel pressure gauge but if I buy that and the fuel pump is bad then thats one more thing a poor college student cant afford. Thinking about just buying a 255lph pump and seeing if that works cause eventually i will need it if i go hci or something else. What do you guys think? This one on ebay any good? or just get a walbro?
http://cgi.ebay.com/ebaymotors/255-...ewItemQQcategoryZ33555QQitemZ8014093929QQrdZ1
loudpedal99
160
ND
Nov 15, 2005
  • Nov 15, 2005
I got my Walbro on ebay from 'mrfuelpump' for $94 shipped. Good luck with it; definately sounds like the pump if priming it repeatedly helps.
tsoccer3299
255
Tacoma
Nov 15, 2005
  • Nov 15, 2005
maybe worth just getting this 155lph pump? what kinda power would a 155 support
http://cgi.ebay.com/ebaymotors/94-9...ewItemQQcategoryZ33555QQitemZ8013647915QQrdZ1
HISSIN50
34
129
Nov 15, 2005
  • Nov 15, 2005
Another vote for a Walbro pump. The size is up to you. It would depend upon what kind of mods and power you plan to make in the future.
Good luck.
9
95cobra50
167
  • Nov 15, 2005
i have a walbro 255lph and i got it for $105 shipped. Got it from jdsperformance.com
tsoccer3299
255
Tacoma
Nov 15, 2005
  • Nov 15, 2005
yeah id get the walbro but i just found that 155lph one on ebay in the link i posted and its real cheap. what do you guys think of it?
95COBRA241
339
Delray Beach, FL
Nov 15, 2005
  • Nov 15, 2005
I'd still say you'd be better off with a Walbro for $30 more than your first selection. With Walbro you know what you are getting. You may be taking a chance with the others.
9
95cobradude
Banned
Apr 1, 2005
194
long island, ny
Nov 15, 2005
  • Nov 15, 2005
255 is way 2 big for your stock motor, 190 would be the limit. even with heads and a cam the 190 would be fine.
tsoccer3299
255
Tacoma
Nov 15, 2005
  • Nov 15, 2005
yeah i realize it is way overkill but on our cars dosent it not matter since we have a return fuel line? eventually i would like to get a supercharger
HISSIN50
34
129
Nov 15, 2005
#10
  • Nov 15, 2005
  • #10
Correct. The return style fuel system passes the extra fuel back to the tank. There are arguable side effects from a too large of a pump (fuel heating, etc), but they are not worth considering. Especially considering your future plans.
Good luck.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Nov 15, 2005
#11
  • Nov 15, 2005
  • #11
+1 for jdsperformance.com I popped in a 255lph a few weeks back. Car runs just fine go for it it won't hurt anything.
tsoccer3299
255
Tacoma
Nov 16, 2005
#12
  • Nov 16, 2005
  • #12
on jdsperformance they have a high pressure 255lph and a regular 255. whats the difference? guessing i dont need the high pressure one maybe?
HISSIN50
34
129
Nov 16, 2005
#13
  • Nov 16, 2005
  • #13
The HP version does not have as much pressure drop off at around 60-70 PSI that the non-HP version does. The HP pump is nice for blower, FMU, etc applications.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • Mindseye007
  • Aug 16, 2026
Mindseye007
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
