Change to throttle by wire
What do you hate about it? You would probably need a new throttlebody to do that and a new gas pedal assembly. If you want to get rid if the lag get a tune. Also if it has slop in it do the calibration for it that's in the manual.
+1 The throttle by wire system is great it frees up so much room under hood, just look at all the different style blowers available, side intake, front intake etc...
A cable throttle wont work anyways, not with the stock computer and adaptive learning function. It would be a waste of time and money to try and make it work if u could get it work.
Throttle Response
I have an '06 GT that has a throttle lag. Sometimes it works fine other times it has a bad lag. I have to recalibrated it almost daily. I got a superchips tuner and have tried several of their tunes but it has only magnified the problem. I added a CAI but that didn't help either. Superchips says they have never seen this problem before. I'm wondering if I just have a bad accelerator pedal. I saw a website but I don't recall which one, where someone took apart their accelerator pedal and bent the contacts which they said fixed their lag problem. I don't think I'm that desperate yet but at this point I'm willing to try anything.:shrug:
Kens1129 it sounds to me like you need to clean your throttle body and maf...maybe. A tune will always make the throttle feel great if set up by a pro or even a boxed tune that comes with the tuner.
Thanks Guys
Thanks Wraith and Anthony. I'll have to check out your suggestions. It's possible the TB could be dirty. I've only had the Stang for 6 months and it has 30k on it. Wraith do you know if any of those companies support the Superchips tuner?
Just cleaned my TB. Runs like a new car. I was surprised it worked because I didn't have any idle problems and I couldn't see any dirt in the TB until I sprayed it. Thanks again Anthony.
