Changed plugs/wires/cap/rotor....Interesing problem
  • Thread starter Thread starter Prime Lord
  • Start date Start date Apr 21, 2008
Prime Lord
Crappy Default Title
2,137
199
114
Denver-ish
Apr 21, 2008
  • Apr 21, 2008
Its tune up time! I put in new Autolite 25s, FMS 9mm wires, & MSD cap/rotor. Based on the stock cap that I took off for the #1 plug, I wired the MSD cap accordingly. Got the order right, but the car wouldn't start. It sounded like it wanted to but the timing was stupidly off. Then I went back and looked at the orientation of the distributer. The harness going into it is almost pointed at me...that seemed like a lot of rotation for timing. So I took all the wires off and replaced them 1 cylinder off. Basically moved all the wires one plug clockwise. She fired right up.
Now, this engine came out of a donor car. Snagged the complete block from the intake to the oil pan. It came to me like that and this is the first time I have changed the plugs/wires.
Is it safe to say that some moron wired the cap wrong and then rotated the distributor to compensate when it wouldn't start?
The other problem I'm having is that when I went up to the store last night, the damn thing is backfiring and going nuts below 2000 RPM. Its great above that, but below it I can't even maintain speed its backfiring so much. Thats the problem I'm at now. I don't remember it doing that BEFORE changing all the plugs.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Apr 21, 2008
  • Apr 21, 2008
That is odd. Did you check the timing? A cheap timing light will do the job. I would set it at the stock 10* and go from there.
HISSIN50
34
129
Apr 21, 2008
  • Apr 21, 2008
I agree with checking the timing. The only caveat with moving plug wires around (like we did in the old days) is that the indexing of the PIP gets thrown off (#1 has a different shudder dimension). Now I realize you did this to make-up for the oddity - it's just info.
Anywho, I like the idea to time it and go from there. You might need to restab the dizzy to get it right.
Good luck.
Prime Lord
2,137
199
114
Denver-ish
Apr 21, 2008
  • Apr 21, 2008
Yeah, I don't have a timing light. So I'll pick one up this week and check it out. I'm pretty sure the timing is fuct.
If I spin the distributor back to approximately where it should be, hook up the wires correctly, and verify the timing, it should run hella better.
Could it being one plug off and over rotated throw a check engine light when the idle screws up? I have yet to pull the codes, but i'm wondering.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
  • Mindseye007
  • Aug 16, 2026
Mindseye007
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
  • brandyn200
  • Jun 20, 2026
AeroCoupe
