Changin the battery
  • Thread starter Thread starter fox racer
  • Start date Start date Nov 24, 2004
fox racer
577
Staten Island, NYC
Nov 24, 2004
  • Nov 24, 2004
ok, i need a battery. i heard optima and die hard gold is the way to go... any opinions? also, is there a certain way i should connect disconnet the positive and negative? i heard thers a certain way, i dun want to mess this up lol. or does it not matter as long as you dont bridge the positive and negative terminals?
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Nov 24, 2004
  • Nov 24, 2004
go with the optima red top, great battery. Disconnect the ground first, then the +12v lead. When you reconnect the battery, connect the 12v lead first, then connect the ground wire.
C
crunchie12268
599
Manhattan, KS
Nov 24, 2004
  • Nov 24, 2004
Yes the Optima Red... buy the trunk mounting kit from summit and re route it to the back while your at it.
blown1989saleen
1,397
oxford,pa
Nov 24, 2004
  • Nov 24, 2004
go with the Optima, i have a red top Optima that is i forget either 7 or 8yrs old and it is still kicking.
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
Nov 24, 2004
  • Nov 24, 2004
i've never heard anyting about optima, i have a die hard and can't complain.... but ya, ground first to disconect, and ground last to connect
Marks5.0!
640
San Antonio, TX
Nov 25, 2004
  • Nov 25, 2004
had an optima red in my 93 since 98ish and its still going strong, kind of expensive but its been the best battery ive ever owned and has lasted the longest of all them
fox racer
577
Staten Island, NYC
Nov 25, 2004
  • Nov 25, 2004
alright, so optima red seams to win, but die hard gold is good if your low on cash... and the install.remove goes like this:
Remove: Ground(Black/-) then Lead(Red/+)
Intall: Lead(Red/+) Then Ground(Black/-)
88_GT_5_oh
Jul 4, 2004
WPG/MB/CA
Nov 25, 2004
  • Nov 25, 2004
yep.... thats how its done
P
PonyBoy90
555
Toronto
Nov 26, 2004
  • Nov 26, 2004
Myself, I have an AC Delco in my 1990 LX. I think it's great. Had it for 3 years now and no problems. AC Delco goes for about $125.
Since you're changing batteries I suggest you purchase a battery disconnect switch. They're pretty cheap, some go for as low as $8. After the swap when you go to put the cables back on the terminals, clamp the disconnect switch to the negative terminal and hook up your negative cable to the terminal on the switch (That is after you hook up the positive first). Benefits of having one of these is you won't have to disconnect (unwrench) the negative ground everytime you need to fiddle with your car's electrical system. All you do is unscrew the switch knob and that'll cut the power.
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
D
1985 Mustang GT Battery Wiring and Grounds
  • DienstXIV
  • Dec 22, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 23, 2024
85GTStangGuy
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
