Changing carb
  • Thread starter Thread starter mhjo
  • Start date Start date Apr 13, 2018
mhjo
490
Oslo, Norway
Apr 13, 2018
  • Apr 13, 2018
I have been running a Edelbrock 600 cfm for a year but ut seems too big (stalls/floods all the time).
Anyone tried the new AVs2 (500) from Edelbrock?
tos
896
68
59
Cincinnati Ohio
Apr 13, 2018
  • Apr 13, 2018
You should not be flooding with that carb if you are talking about the engine that is listed in your sig. With those kind of mods you should be good to go with that carb right out of the box. I'd be looking for problem with the carb such as float level or if you are running an electric or performance mechanical fuel pump then I would check the fuel pressure at the carb. You should have a pressure regulator with those pumps to regulate the pressure to around 6 psi otherwise you'll be forcing fuel into the fuel bowl and the float can't hold it back. I don't think I'd go down to a 500 cfm carb when running that RPM airgap, those heads and that cam.
Reactions: rbohm
rbohm
6,698
550
204
tucson,az
Apr 14, 2018
  • Apr 14, 2018
tos is right, you have an issue other than too large a carb. too much fuel pressure, a bad needle and seat, too high a float level, these are things that can cause flooding.
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Apr 15, 2018
  • Apr 15, 2018
I had the same problem where the fuel pump was putting out too much pressure. I wound up putting a regulator in to cure it.
mhjo
490
Oslo, Norway
Apr 18, 2018
  • Apr 18, 2018
Thanks I will have someone to look at the carb!
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Engine Edelbrock 1406 install help
  • scottcarp10
  • Dec 11, 2025
Fox 5.0 Mustang Tech Dec 15, 2025
scottcarp10
