Changing diff. fluid
  • Thread starter Thread starter Dtowncats
  • Start date Start date Jun 5, 2005
D
Dtowncats
340
York, PA
Jun 5, 2005
  • Jun 5, 2005
What is the proper way of putting it back together. RTV gasket around the edge and bolt holes, Loc-tite on the bolts, any specific number to torque the bolts to? Should I wait until the gasket dries to put the fluid in or will it be okay to put it in right away?
bimmertech
1,123
merriam, ks
Jun 5, 2005
  • Jun 5, 2005
I Don't Ever Use A Gasket On My Diff Cover, Just A Bead Of Rtv. I Don't Use Loctite Either, As Far As Torque I Usually Go To One Grrr With A 3/8 Ratchet. I Put The Fluid In Right Away And Drive It Befor The Rtv Dries. Good Idea To Also Remove The Axle Vent And Give It A Good Clean Or Replace.
hllon4whls
BANNED
2,567
Covington
Jun 5, 2005
  • Jun 5, 2005
Torquing the cover is not too big of a deal IMO.
Just make it fairly tight. You dont have to put all of your strength into it. Loctite might help keep the bolts in there, but I dont run it either.
Bead of silly cone is what most people run for a gasket.
D
Dtowncats
340
York, PA
Jun 5, 2005
  • Jun 5, 2005
Ok, thanks guys. Just thought I would make sure.
HISSIN50
34
129
Jun 5, 2005
  • Jun 5, 2005
your repair manual should have a spec for the cover's bolts.
I use a gasket and RTV, but no threadlock on the bolts (on the 12MM 12 point bolts which attach the DS to the pumpkin, yes. But not on the cover bolts).
Good luck.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jun 5, 2005
  • Jun 5, 2005
I've also never used LocTite, just snug the bolts up. It's important not to overtighten them as the cover can warp (like steel valve covers) and then you can have sealing problems.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jun 6, 2005
  • Jun 6, 2005
Its 25 Ft Lbs of Torque and you do it in a criss cross as you would mounting a wheel on your car. I am in the minority, I use a FMS Gasket.
hotrodnut
672
North Florida
Jun 6, 2005
  • Jun 6, 2005
Good info on the torque process. I like a gasket too because there is no time required for your car to be driven. That said, If you do use silicone let it dry/cure before heading out.
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
  • dan50
  • Jul 18, 2026
dan50
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
