Changing Oil
savegoodautonfg
1,085
I put an extra quart of oil during my oil change and then realized im only suppose to have 5 quarts in there. i havent drove it so my question is to drain a quart, could i just take out oil filter cuz i know that the oil filter is filled up with a quart. so could i jsut unscrew the oil filter and dump out the oil from the oil filter and screw the filter back on?
thanks
from what i've read the front "hump" in the oil pan holds just over a quart, so if you remove the front plug not much more than a quart should drain oil, but you should still check the oil level when you're done
~Mark~
