Changing valve seals...?
  • Thread starter Thread starter cjman15
  • Start date Start date Jun 3, 2005
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jun 3, 2005
  • Jun 3, 2005
I've been told I'm probably burning oil from leaky valve seals... are these easily fixed besides taking apart tha upper intake, valve covers and tha other accessories? If it's possible to do myself, I'd like to try before taking it somewhere... just want to stop it from burning if I can.
Zero_chance
1,244
Maricopa, AZ
Jun 4, 2005
  • Jun 4, 2005
Its not that bad if you have some time set aside to do it and the right tools. Knowing what youre doing is very important. Its possible to do it with the heads in the car still but when I did mine I went the extra steps and just took the heads off. If you do it with the heads in the car you have to use regulated shop air into the spark plug hole to keep the valves from falling into the cylinder. The actual process of changing them is relatively easy. Just take the old umbrella style off (mine were in pieces I might add) and then put some white lith on the inside diameter of the new seal, where the valves stem slides. I recommend the Fel Pro blue intake seals and the Fel Pro black exhaust seals. Theyre made of I think its called Viton. The good thing about taking the heads off is you can then clean some of the carbon build up and junk off the valves and even the pistons.
BTW, I like your quote so much I told it to a bunch of my friends. I even told it to my ex but she wasnt as amused as everyone else...
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
A
Engine Genius installed oil filler above rocker arm…
  • afjLX
  • Mar 27, 2025
Fox 5.0 Mustang Tech Mar 29, 2025
nicholase
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
