charge motion control valves
A quick Google search, I found this.
FORD RACING charge motion control valve (CMCV) assemblies
4.6/5.4L SOHC 3-Valve
Remove the restriction of CMCV blades and shafts by installing a set of Ford Racing charge motion control valve (CMCV) assemblies. Reduce turbulence and improve airflow in the intake. Ford Racing CMCV DELETE plates require computer recalibration for use which is available and installed on all DiabloSport predator tuners. Once tuned Ford Racing CMCV DELETE plates (charge motion plates) you will not have sacrifice any low end torque and provide midrange and upper rpm horsepower and torque increases. Peak increases of up to 10 horsepower on naturally aspirated applications, even more on supercharged applications!
Installation of this kit is quite simple and should take no more than 2 hours to complete.
EDIT: If I remember correctly, on the 2007+ Mustangs the Control Motion Plates are molded into the intake and can NOT be replaced, but, if you have a 05 or an 06 you can change them out.
The integrated plates are on the 09 and 10. The 05-08 can be replaced with the units that are pictured above. You replace them to increase airflow, if you plan on getting a roots type supercharger then its not required to buy them. If you're going to stay N/A or go with a turbo or centrifugal style SC then get them.
I have a set on my 06. I got a tune from Bama on my SCT... couldn't have been an easier install.
A simple chiltons manual, IN.-LBS Torque Wrench, a torx bit and about an hour and the job is done.
If you don't know what your looking for, you'd never notice the new piece visually. Which, personally, adds some eye candy for you.
Otherwise, I noticed some good gains. Hope this helps!
